02 Intrepid PCM #1765144
02/28/15 11:48 AM
02/28/15 11:48 AM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
We are trying to locate a PCM for an 02 Intrepid. We are up in Ontario Canada. Anyone have suggestions on where to look? We have been told the one in the car is not repairable. New or used?
Steve
Re: 02 Intrepid PCM [Re: SSDart] #1765145
02/28/15 12:07 PM
02/28/15 12:07 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
the one on our '04 217,000 mile Intrepid was good. When we traded the car in yesterday the dealer said the car was headed for the junkyard.
1981 Dodge D150 360 auto
Re: 02 Intrepid PCM [Re: SSDart] #1765146
02/28/15 02:17 PM
02/28/15 02:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What color is they key, black grey or plain metal?
The grey one has security and you can not just stick any computer in it, those will need programed by the dealer, most dealer techs do not know how to do this with a used computer.
If it is black or plain metal you can get a computer from any other same/similar year intrepid and stick it in if it does not have the grey key. A 2.7 3.5 and 3.2 computer is interchangable, fuel trim ends up slightly off but not enough to worry about.
I have pulled a lot of 2.7s out and swapped to 3.2-3.5s and left the factory computer in and they run just fine with no codes even though the engine is way different
300m LHS Conchorde of the same vintage will work following the same rules
