Re: How to Test HORNS properly???
[Re: moparphilll]
#1765134
02/28/15 11:54 AM
02/28/15 11:54 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Not sure about the proper part but I always ground the mounting flange and put power to it so a second or 2. That's how they operate so I cant see it hurting one and have never damaged one to my knowledge, of course I live in the woods so I'm sure there's a better way and soemone will tell me I'm nuts.
Careful, your character's showing!
[Re: moparphilll]
#1765138
02/28/15 01:57 PM
02/28/15 01:57 PM
RapidRobert
If your horns have a mini trimmer knob on the case, you can turn it SLIGHTLY CW then back to where it was, then SLIGHTLY CCW, then back to where it was (originally) & this will alot of times improve the sound quality. I'm assuming your sound (as is) ain't up to snuff
[Re: RapidRobert]
#1765139
02/28/15 01:59 PM
02/28/15 01:59 PM
Posts: 2,578 Fargo ND
moparphilll
Fargo ND
Are horns fixable if they stop working?? I will try above technique to see if it fixes any THANKS
[Re: moparphilll]
#1765140
02/28/15 02:10 PM
02/28/15 02:10 PM
RapidRobert
OK, you have a completely dead one. Try the knob & if no go then it has to be opened up but maybe go a bit further either way from dead center (~1/16 of a turn max maybe) but be conservative with it first. As said make sure the bare metal on the case is grounded then jump fire to the terminal. I'm thinking the knob wont fix a dead one but see what happens. it has restored a good sound on one that the tone is off. Do ya feel lucky? well do ya
[Re: RapidRobert]
#1765141
02/28/15 02:15 PM
02/28/15 02:15 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Exactly. you will also find out that there is a "LO" and a "HI" toned horn in the set. This is one of the most annoying procedures you will experience. I suggest earplugs and some where alone. You make a lot of noise if you don't get em adjusted quickly.
[Re: moparphilll]
#1765142
02/28/15 08:08 PM
02/28/15 08:08 PM
Posts: 6,516 Santa Cruz, California
Lefty
What is the correct way to test horns without damaging them? Thanks in advance
If my cat is stuck to ceiling in the garage after a brief toot, they're good.
I use a wire with a 10 amp fuse from a car battery as power and my Power Probe to trigger the factory relay.
