Alum driveshaft limits
#1765033
02/28/15 02:01 AM
02/28/15 02:01 AM
Posts: 289 Lowes
steve660
Lowes
What's the limit on an aluminum driveshaft. I had DTS make a 4" alum one with 1350 u joints a while back. No problems behind old 496 making close to 700hp. Car weighs 3500lbs and new engine will be making 950 hp. Car is a foot braked E body with 727 and Dana 60.
EDIT.....I was wrong, current driveshaft is 3 1/2 " diameter. 42 1/2" center of u joint to center of u joint...
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: Alum driveshaft limits
[Re: 408Dust]
#1765035
02/28/15 04:14 PM
02/28/15 04:14 PM
Posts: 289 Lowes
steve660
Lowes
Car should trap 6800-7000. Ive heard others swear don't use aluminum drive shaft. I think mine has held up good. Put it in and forget it.
[Re: steve660]
#1765036
02/28/15 09:03 PM
02/28/15 09:03 PM
Posts: 9,860 MI, usa
dvw
MI, usa
1.29, [Email]9.12@147[/Email], 3340lbs foot braking. 44.5"x 3.5" aluminum from Dyno-tech. No issues 200 passes. Doug
[Re: Ben Holt]
#1765038
02/28/15 10:24 PM
02/28/15 10:24 PM
Posts: 289 Lowes
steve660
Lowes
Thanks guys. Looks like i'm gonna be ok with current alum driveshaft.
[Re: steve660]
#1765039
02/28/15 10:29 PM
02/28/15 10:29 PM
Posts: 289 Lowes
steve660
Lowes
UPDATE......I was wrong on the diameter. It's 3 1/2" diameter and it measures 42 1/2 center of u joint to center of u joint.
