Steering Stabilizer Shocks #1764755
02/27/15 11:03 PM
02/27/15 11:03 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
How do you determine how many you need? I only have one right now and was wondering if I need another.
I have 8" suspension lift with 37" tires now, but have room for 44" tires and plan to get some within the next year.
Re: Steering Stabilizer Shocks [Re: Brad4406] #1764756
02/28/15 12:41 AM
02/28/15 12:41 AM
IN
ahy Offline
ahy  Offline
IN
How does it drive? If OK at speed, OK with one shock. Alignment has as much or more to do with stability vs shocks. Some positive caster and factory spec or higher toe in (with big tires) promotes stability.
Re: Steering Stabilizer Shocks [Re: ahy] #1764757
03/02/15 10:47 PM
03/02/15 10:47 PM
Lebanon, OH
Brad4406 Offline OP
Brad4406  Offline OP
Lebanon, OH
It drives better now without the Swampers. When it had those tires, it was risky changing lanes at speed.
Re: Steering Stabilizer Shocks [Re: Brad4406] #1764758
03/03/15 08:32 AM
03/03/15 08:32 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Stick with radial tires.
Angry white pureblood male
