Page 1 of 5 1 2 3 4 5
weak small block #1764253
02/27/15 02:13 PM
02/27/15 02:13 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
On my Shaggin Wagon, I put a 4bbl intake and edelbrock 600 avs on it. I was doing some tuning yesterday and decided to drive it without the dog house or aircleaner on it. it wont even open the air door on the secondaries when floored.
thinking about a 450 holley. Never tried one but they have just one squirter and open the secodaries mechanically. Any have any thoughts on this?
Re: weak small block [Re: sixpackgut] #1764254
02/27/15 02:17 PM
02/27/15 02:17 PM
Canada
onig Offline
onig  Offline
Canada
It's been a long time, but I think the spring is adjustable on that.
69 Dart
Re: weak small block [Re: onig] #1764255
02/27/15 02:22 PM
02/27/15 02:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
put a dang 650 vac secondary holley and be done with it. will give your more performance and better mileage. you are way over thinking this
Re: weak small block [Re: sixpackgut] #1764256
02/27/15 02:34 PM
02/27/15 02:34 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It takes air speed to open the secondaries. Weak motors move no air, so all you have to do is use a weaker spring on the secondary doors.
I wouldn't use the 450 Holley. The 650 Quick suggested will be fine. But same deal, you will have to tune the secondary with a weaker diaphragm
Monte
Re: weak small block [Re: Monte_Smith] #1764257
02/27/15 02:40 PM
02/27/15 02:40 PM
Charleston
Charleston
but that is no different the the 600 Edel I already have on it. If it wont pull the seconday air flap open, and I think I have it as lose as it can be, why would you guys think the Holley secondaries will open?
Re: weak small block [Re: sixpackgut] #1764258
02/27/15 02:43 PM
02/27/15 02:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well for one i wouldn't put a eddy carb on anything they are both adjustable with springs. they wont open until needed. how long did you hold the pedal down? it wont open the second you mash the gas either way.
Re: weak small block [Re: Quicktree] #1764259
02/27/15 02:47 PM
02/27/15 02:47 PM
Charleston
Charleston
The Edel carbs work great. I know some people hate them but they really work very well. I was pushing the air door open with my finger Damn thing is so slow. I drive it every day but its just such a dog
Re: weak small block [Re: sixpackgut] #1764260
02/27/15 04:05 PM
02/27/15 04:05 PM
an8sec70cuda Offline
Ray...I have heard of motors being weak enough that they'd never open the secondaries like you're seeing.
Seems like you have a few options...deal w/ it, rebuild it, or get a mechanical secondary carb.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: weak small block [Re: an8sec70cuda] #1764261
02/27/15 04:26 PM
02/27/15 04:26 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
advance the cam
Re: weak small block [Re: Mopar-Al] #1764262
02/27/15 05:35 PM
02/27/15 05:35 PM
Charleston
Charleston
Its running so great right now, maybe I just dont mess with it. Needs converter and gear.
Re: weak small block [Re: sixpackgut] #1764263
02/27/15 05:46 PM
02/27/15 05:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I removed the 318 and installed a 360 I built many many years ago in my van to give it some more get up and go and it worked out real nice. .030 over 360, RV cam, headers, LD4B intake, 650 vacuum holley, and a set of J heads. Man that thing not only towed nice but got better gas mileage than the stock 318. I miss that van.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: weak small block [Re: pittsburghracer] #1764264
02/27/15 06:08 PM
02/27/15 06:08 PM
pennsylvania
poboyengineering Offline
pennsylvania
Sweet van!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: weak small block [Re: poboyengineering] #1764265
02/27/15 06:18 PM
02/27/15 06:18 PM
Charleston
Charleston
Damn, I like that van. My GF was laughing at all the thumbs up I got at SGMP rolling thru the pits with mine. And mine is ugly!
Re: weak small block [Re: sixpackgut] #1764266
02/27/15 06:32 PM
02/27/15 06:32 PM
PA.
"Little"John
"Little"John
PA.
Man I had some good times in that van. When I would jump on it with my girlfriend in it I would flip this switch that was mounted on the dash and tell her it was turning on the nitrous. 2 years later I found out the switch was actually turning on my reverse lights. I'll bet that messed with some minds.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: weak small block [Re: sixpackgut] #1764267
02/27/15 06:32 PM
02/27/15 06:32 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I've got a 73 duster with a 318 600 holley, edelbrock intake, stock exh man and a single 2" exhaust and it wouldn't pull the skin of a rice pudding. I've checked the timing and adjusted the carb but it just sounds so flat, i swear it's one of the slowest cars i've ever owned. Lol
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: weak small block [Re: sixpackgut] #1764268
02/27/15 06:33 PM
02/27/15 06:33 PM
Earth
Rob C Offline
Rob C  Offline
Earth
The AVS's adjustable secondary air door via the spring should be an easy adjustment. If it is not opening the door on the carb as delivered, it makes me wonder if the factory over tightened it or the engine just doesn't want the extra flow.
Take it down the road and listen for the opening and make note of the rpm of where it happens. 600 cfm on a stock engine is a lot. Not that it can't or won't use it all but by the time it wants the extra amount, it may be late in the rpm band.
Re: weak small block [Re: sixpackgut] #1764269
02/27/15 06:38 PM
02/27/15 06:38 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Something to check.There should be a choke lockout on the secondaries,it may be misadjusted even if the choke is open. Wont cost anything to check.
Re: weak small block [Re: 67_Satellite] #1764270
02/27/15 06:49 PM
02/27/15 06:49 PM
Charleston
Charleston
I have the air door spring so loose, its about to fall open and it wont.
How do you change motors in a van, thru the passenger door?
Re: weak small block [Re: sixpackgut] #1764271
02/27/15 07:27 PM
02/27/15 07:27 PM
PA.
"Little"John
"Little"John
PA.
That's how I did it and all went well. (4 bolts and the front seat was out) That was the first time I used a plate bolted to the carb flange and that really helped. I loaned my plate to a guy installing a 440 I build for my Dad's 1977 Dodge class C motorhome and he couldn't get over how well that worked out for him instead of the old chain set-up.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: weak small block [Re: pittsburghracer] #1764272
02/27/15 08:55 PM
02/27/15 08:55 PM
dogdays Offline
dogdays  Offline
I just put a NOS 450 Holley Model 4360 on my 318. Throttle response was better than the 570 Street Avenger that was sitting on top of an adapter.
I was feeling really hopeful about the carb when I started computing mileage. Looks like this carb needs tuning as well, mileage dropped noticeably from the 570.
Some people have gotten the Model 4360 to work, but I'd stick with a Quadrajet or T-quad.
R.
