weak small block
#1764253
02/27/15 02:13 PM
02/27/15 02:13 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
On my Shaggin Wagon, I put a 4bbl intake and edelbrock 600 avs on it. I was doing some tuning yesterday and decided to drive it without the dog house or aircleaner on it. it wont even open the air door on the secondaries when floored.
thinking about a 450 holley. Never tried one but they have just one squirter and open the secodaries mechanically. Any have any thoughts on this?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: weak small block
[Re: sixpackgut]
#1764254
02/27/15 02:17 PM
02/27/15 02:17 PM
Posts: 361 Canada
onig
Canada
It's been a long time, but I think the spring is adjustable on that.
69 Dart
[Re: Monte_Smith]
#1764257
02/27/15 02:40 PM
02/27/15 02:40 PM
sixpackgut
Charleston
but that is no different the the 600 Edel I already have on it. If it wont pull the seconday air flap open, and I think I have it as lose as it can be, why would you guys think the Holley secondaries will open?
[Re: sixpackgut]
#1764258
02/27/15 02:43 PM
02/27/15 02:43 PM
Quicktree
well for one i wouldn't put a eddy carb on anything they are both adjustable with springs. they wont open until needed. how long did you hold the pedal down? it wont open the second you mash the gas either way.
[Re: sixpackgut]
#1764260
02/27/15 04:05 PM
02/27/15 04:05 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Ray...I have heard of motors being weak enough that they'd never open the secondaries like you're seeing. Seems like you have a few options...deal w/ it, rebuild it, or get a mechanical secondary carb.
[Re: poboyengineering]
#1764265
02/27/15 06:18 PM
02/27/15 06:18 PM
sixpackgut
Charleston
Damn, I like that van. My GF was laughing at all the thumbs up I got at SGMP rolling thru the pits with mine. And mine is ugly!
[Re: sixpackgut]
#1764266
02/27/15 06:32 PM
02/27/15 06:32 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I had some good times in that van. When I would jump on it with my girlfriend in it I would flip this switch that was mounted on the dash and tell her it was turning on the nitrous. 2 years later I found out the switch was actually turning on my reverse lights. I'll bet that messed with some minds.
[Re: sixpackgut]
#1764267
02/27/15 06:32 PM
02/27/15 06:32 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I've got a 73 duster with a 318 600 holley, edelbrock intake, stock exh man and a single 2" exhaust and it wouldn't pull the skin of a rice pudding. I've checked the timing and adjusted the carb but it just sounds so flat, i swear it's one of the slowest cars i've ever owned. Lol Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 67_Satellite]
#1764270
02/27/15 06:49 PM
02/27/15 06:49 PM
sixpackgut
Charleston
I have the air door spring so loose, its about to fall open and it wont.
How do you change motors in a van, thru the passenger door?
