Re: Heat cracking on main journal, is it safe??
[Re: DemonDust]
#1764150
02/27/15 04:19 AM
02/27/15 04:19 AM
Posts: 2,004 s. e. pa.
calrobb2000
s. e. pa.
hi i would have it ground and re check for cracks . grinding .010 onlyy removes .005 of the surface. may have to go more to remove cracks depending on depth of cracks . when cracks are gone it will be good as new .
[Re: BPE]
#1764163
02/28/15 02:48 AM
02/28/15 02:48 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
If you want a 2nd opinion you may want to give http://www.shaftech.com/ a call.
Rod
I called them. They said I might want to be careful with nitriding the crank if the cracks aren't gone. He said more than likely .020 won't get rid of them. So if the crank would get nitrided again the cracks could open up and cause a squeegee effect on the bearing. Problem is the number 5 bearing is the hardest of all to work on. And most expensive. He said he'd check it for round and if that's good he'd run it since I've been running it for 5 years with no issues. He said it's not going to crack anymore than it already is.
If I want to fix it and bring it back up to stock size it would be around $600.
