Everyone has there preference. The most important is to make sure nothing binds in the suspension. I just use the factory shackles. If you go with sliders they go on the rear.
I still use shackles on the rear...been 1.32 sixty foots footbraking at 3850 lbs. on radials. The sliders are supposed to be a little better, but I've seen where some have said they made no difference. ![](/ubbthreads/images/graemlins/shruggy.gif)
