39 Dodge #1763532
02/26/15 12:58 PM
02/26/15 12:58 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
....I'll post pics later....customers car....It had a 350/350...long gone now....still has the 10 bolt cheby rear....wouldn't mind changing that too.....but does anybody have pictures of motor mounts for our mopar motors that I could take a gander at...this has stock front, other that it had disks put on...but as far as the suspension goes....I'm thinking it's stock, again I'll take pictures.....any help guys would be appreciated.
Moparlee
Re: 39 Plymouth [Re: Robbins] #1763533
02/26/15 01:10 PM
02/26/15 01:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure what you are asking for.
Stock flathead 6 motor mounts?
Or are you asking for pictures of later engine mounts?
If you are gonna fab something up just grab a set of later spool mounts and use those, readily available and rockauto has pictures.
That's for a 318, B/RB are similar.
Don't be the exception.
Re: 39 Plymouth [Re: Robbins] #1763534
02/26/15 02:15 PM
02/26/15 02:15 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
Re: 39 Plymouth [Re: Supercuda] #1763535
02/26/15 02:24 PM
02/26/15 02:24 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks....I was referring to pictures of motors in the car, that are done already.....ideas....food for thought on my part.
Moparlee
Re: 39 Plymouth [Re: Mopar Ron] #1763536
02/26/15 02:35 PM
02/26/15 02:35 PM
Mopar Ron Offline
Mopar Ron  Offline
here are a few more pics
Re: 39 Plymouth [Re: Mopar Ron] #1763537
02/27/15 12:37 AM
02/27/15 12:37 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A 39 Plymouth has the same basic frame as the 46-48 Mopars. I've made motor mounts for at least 4 of these cars, but I don't think I ever took pictures. Basically set the engine where I wanted it, and built my brackets off the side frame rails that would attach to the rubber parts of the motor mount brackets on the engine. I might suggest you bolt on the exhaust headers or manifolds to be sure where you mount the motor clears everything.
You will need a rear sump oil pan.
If you offset the motor to the right (passenger side) 1 1/2" to 2", you will clear the steering column.
If you notch and box back in the front crossmember so it will Make sure you have enough clearance to put belts between the crossmember and the pulleys when your done).
You will want to modify the lower 6" of the firewall bump (a hammer will work) on the right side (passenger side) to give additional clearance for the head. Gene
Re: 39 Plymouth [Re: poorboy] #1763538
02/28/15 10:54 AM
02/28/15 10:54 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Thanks guys.
Moparlee
Re: 39 Plymouth [Re: Robbins] #1763539
02/28/15 11:58 AM
02/28/15 11:58 AM
Az
Crizila Offline
Crizila  Offline
Az
I went with stock style motor mounts on my 360 as I liked the location - pretty much on the crank center line. Since I am building a driver, I wanted to keep drive train vibration to a minimum.
Fastest 300
