'49 Dodge engine swap
#1763265
02/26/15 01:59 AM
02/26/15 01:59 AM
Posts: 11 New York
Andyjon100
New York
Hello, all! I'm a Mopar nut from way back, who kinda fell out of the hobby for (too many) years. My list of priors : 1960 New Yorker 6 passenger T&C wagon, '72 & '73 New Yorkers, '54 Imperial, '72 Road Runner 440 - 4, '64 Valiant convert, '66 barracuda "S", '76 Feather Duster, and '66 Charger. The bug bit me again, when a guy I know told me he was selling his '49 Dodge.It is an early production '49, so it's physically a '48. He built is as a mild '50's style rod, flat 6 with a shaved head, 3x2's, header, etc. At some point several years ago, he decided to put an O.D. tranny in it to make it more highway drivable. He bought the tranny supposedly rebuilt, but when he got it in, there was no reverse. He got sick, and it has sat since. I bought it after a real quick look-see, and with the body and interior as near mint as they are, coupled with a steal of a price, I didn't really care about the rest. The fuel system needs a flush, it runs when gas is added to the carbs, so I know the motor is good. NOW... It still resides in his garage, waiting for the temps around here to climb back above ZERO to bring it to MY garage......and my uncle passes away. I talk to a cousin I haven't seen in years, and he tells me he's got a model A he wanted to street rod using a '52 331 Hemi he just had gone through, but just doesn't have the time. He'll sell me the motor and all the parts he bought for it for a song. Anyone have any thoughts on yanking the 6 out for the Hemi? I'm not looking for a street race king, I'm more looking for a nostalgia rod that some high school kid would have built out of Dad's old family car in the '50s.....I bought this car to be able to pile my wife and kids in on a Sunday afternoon with their bikes, a cooler and a grill. Thanks in advance for your input!
Re: '49 Dodge engine swap
[Re: Andyjon100]
#1763268
02/26/15 03:14 AM
02/26/15 03:14 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Thanks! How do I get it moved?
I'll hit the Notify the Mod button. They may not like it, but we'll see.
[Re: Crizila]
#1763270
02/26/15 07:20 PM
02/26/15 07:20 PM
Posts: 11 New York
Andyjon100
New York
Pics will be forthcoming, as soon as the block of ice encasing the garage thaws! LOL! I'm chomping at the bit myself! He threw in the good Fluid Drive trans he took out of it, as well as a ton of other extra parts.( However, I don't know what he put IN it for a tranny, I haven't been under it) I don't want to use anything on this car that wasn't around in 1955 or '56. Like I said, the whole car was done in the mid to late 80's and has been beautifully maintained up until the last 2 or 3 years, the amount of time it's been sitting undriven. What would this kind of swap entail? What trans to use, motor mounts /adapters, suspension... I'm still trying to find out what's available out there that ISN'T muscle car related....I haven't put a car together in about 20 years, and even then, none of them were mods....just stock restos. However, having both the car AND a finished motor practically dropped in my lap for next to nothing, Fate isn't speaking to me, it's SCREAMING at me!
[Re: Andyjon100]
#1763271
02/26/15 10:51 PM
02/26/15 10:51 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Lurk over at the P15 D24 forum and the Imperial club forum.Both will have info you need.
IMHO, I would not bother with the swap unless you gotta be in the garage to be happy. The 331 is a better motor, but it's still pulling 3500-4000 pounds of 6 volts positive ground metal. Either keep the car close to stock and enjoy, OR build something lightweight for the small cube hemi.
If you get into a swap, it starts into mission creep. Better brakes for the idiots out there and the increased power. Might as well convert to 12V. Better rear axle for the extra power. Might as well go with studs and lug nuts by now. The hemi was single exhaust and the chassis is a challenge to put duals into, but I gotta hear that hemi. The stock manual trans and the fluid drive are old tech. Might as well adapt a 727 or even better, a 518. Tha means a new driveshaft to go from turnnions to U joints. At this point, you might as well get a 89-03 dodge van with V8 magnum and auto as a donor and forget the early hemi. Or move up to a 3rd gen hemi donor.
Early hemis are cool; I love 'em. But they are big, heavy and under-powered for the effort unless hopped up and installed in something light.
[Re: RodStRace]
#1763272
02/27/15 12:12 AM
02/27/15 12:12 AM
Posts: 10,555 Freeport IL USA
poorboy
Freeport IL USA
A 52 331 will have the extended bell housing cast into the engine block. That will put a limit as to what transmission you can use. You will probably be ahead of the game to have the trans that is now attached to the Hemi rebuilt or replaced with another like it in better condition. A 52 331 Hemi in a stock rebuilt condition makes 180 HP at 4200 rpm. That is less HP then the currently available V6 engines, but is 77 HP more then the 49's original flathead 6. How much more HP your supped up flathead 6 makes might surprise you. With having a modified flathead 6, I'm not sure a 52 Hemi will be much of a step up, considering the effort involved it getting it there. A 3 carb flathead 6 is almost as impressive as an old Hemi under the hood. At minimum, to change the flathead 6 to the Hemi, your looking at: motor mounts, exhaust, wiring modification, inner fender modifications, a transmission for the Hemi, possibly a driveshaft, and a lot of work. The process will involve removing the hood, radiator, inner fenders, pulling off the front sheet metal, removing the flathead 6 and its transmission, modifying the frame to adapt the new Hemi motor mounts, fitting the Hemi and its trans, modifying the wiring, remounting the front sheet metal, installing a radiator capable of cooling the Hemi, modifying and reinstalling the inner fenders to give side clearance for the Hemi, and having an exhaust system made for the Hemi. I'm sure I missed something, and any time you speak Hemi, the price of anything doubles, even the old low power versions.
The flathead 6 motors were pretty good motors that were capable of moving the cars along quite well. They were not race cars, but not dead dogs either. The fluid drive transmission flat killed the power from them, and the rear gearing turned them at pretty high rpm at highway speeds. There are several modern automatic transmissions that can be installed behind the flathead 6 that will perform well, probably the reason the guy you got the car from was adding an OD transmission. I would that the one you have rebuilt or replace it with another in better condition. You will have a nice cruiser that will be a fun family ride.
As far as the other upgrades mentioned above, they do tend to happen. I would suggest an upgrade to the 12 volt system though. Gene
[Re: moparx]
#1763277
02/27/15 04:37 PM
02/27/15 04:37 PM
Posts: 11 New York
Andyjon100
New York
It is a Fluid Drive car. He bought an O.D. transmission for it, because it would scream going down the thruway - It has something like 4.11's in the rear end. He didn't want to change the gearing, because the acceleration would suffer with the 6, so he bought the transmission which was claimed to have been rebuilt. There is no reverse for some reason though. He got sick and the car has sat ever since. I bought the car 2 weeks ago, and at this point, only possess the paperwork. With the nasty winter we've been having, the guy's 2nd garage where the car is got plowed in. Getting the car out isn't happening right now.With temps in the negative numbers, The car is there until the spring thaw. I didn't really get too thorough with it when I bought it, but cosmetically the car is beautiful, having been completely redone in the mid to late 80's. The old guy I bought it from had a stroke a few years ago, and he is difficult to understand at times.
[Re: Andyjon100]
#1763279
02/27/15 05:17 PM
02/27/15 05:17 PM
poorboy
Freeport IL USA
Sounds like a better plan then ripping everything apart to put a low performance Hemi in it. What body style is your 49? I don't suppose you happened to get any pictures of it you would like to share? We are all a bunch of picture junkies. It sure seems like a spring thaw is a long way off this year, even though Sunday is the 1st of March. Sure couldn't tell by looking out the window at my Plymouth coupe buried under snow along side my driveway. We've gotten more snow in Feb then we got all the rest of the winter. Gene
[Re: Andyjon100]
#1763281
02/28/15 01:23 AM
02/28/15 01:23 AM
RodStRace
Chino Valley
Glad that you have come to your senses! I wrote that big list because that's often what happens when someone tears a car apart to make a couple changes. It sounds like it will be fine once the trans is fixed. If you still want more at that point, I'd suggest a 5 speed manual, driveshaft and a 3.23 rear axle. It will be a blast and still cool under the hood. The hemi would be just a ton of work for little gain. Here's a similar one from the net...
[Re: RodStRace]
#1763282
02/28/15 02:37 AM
02/28/15 02:37 AM
Posts: 11 New York
Andyjon100
New York
I thought the Hemi would give it a bit more oomph and look badass under the hood.....That coupled with the thought of getting a fresh 331 Hemi for $1200.....I really just want it to be able to keep up with traffic on the thruway 65 - 70 mph comfortably. Like I said, this car is going to be used as it was meant to be during the summer....an almost daily driver. Picnics, park trips, beach runs camping.....It's going to be babied, but it's going to be used. The pic you posted looks almost exactly like mine, except mine has skirts, a visor, wide whites with baby moons, I can't see the front, but mine has 50's period fog lights and bumper overriders. It's also been lowered 2". I gotta say... I like that body better than the one they came out with for '49! I'm not going to do anything with the tranny that would require modifying the column, mounting out of place floor shifters, or anything like that. I love the look of the dash/wheel/interior in general too much to go screwing around with it. As more and more of these cars get hacked up and modernized, it leaves precious few originals out there. Although mine isn't "original" it wouldn't take much to get it back there.....I personally have an affinity for the look and feel rods of our fathers, although I may consider a brake upgrade for safety reasons-maybe power discs..... anyone know what's out there interchange wise?
[Re: RodStRace]
#1763283
02/28/15 12:10 PM
02/28/15 12:10 PM
Posts: 7,506 Az
Crizila
Az
"gotta be in the garage to be happy". Mission creep for sure. I know we have all experienced it. I used to use it to sell my wife on buying stuff - until she got wise. Now I have to submit a plan ( with a budget ) for her to review.
Fastest 300
