Very nice set of R&R custom rods I just received #1762763
02/25/15 05:07 PM
02/25/15 05:07 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'm building a 900-1,000hp NA and 500hp Nitrous B1 572 pump gas Drag Week motor for a buddy and thought you guys might enjoy seeing a set of very nice rods we ordered for it.
7.100 .990 pin 2.200 rod ARP 625 bolts
They are between 50-150 grams lighter than the other makers and as strong if not stronger than all of them. So we get a very nice strong steel rod with almost Aluminum rod weight.
They look wimpy next to the 7.100 Eagle rods I have but they use much better material, better strengthening processes and are cryogenic treated, stronger, much lighter and less bulky/cluby.
They have these rods in 2,500hp motor with great success.
I was sort of surprised they weren't I-beam but they said those would be 80+ grams heavier and don't need them for this application. They said that in longer rods I-beam can fold because they can't spread the load out enough.
Great small family style company to deal with, very friendly and very helpful. (thanks Monte Smith for turning me on to them!)
Here are the rods we looked, consider and compared before going with R&R.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762764
02/25/15 05:08 PM
02/25/15 05:08 PM
Tulsa, Ok
Tulsa, Ok
rod
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762765
02/25/15 05:08 PM
02/25/15 05:08 PM
Tulsa, Ok
Tulsa, Ok
rod 2
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762766
02/25/15 05:08 PM
02/25/15 05:08 PM
Tulsa, Ok
Tulsa, Ok
rod 3
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762767
02/25/15 05:09 PM
02/25/15 05:09 PM
Tulsa, Ok
Tulsa, Ok
Rod 4
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762768
02/25/15 05:09 PM
02/25/15 05:09 PM
Tulsa, Ok
Tulsa, Ok
rod 6
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762769
02/25/15 05:30 PM
02/25/15 05:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Those do look light, especially at the small end.
I assume the big end width is 0.992"
What is the width at the small end? 1.062-1.125?
Re: Very nice set of R&R custom rods I just received [Re: 440Jim] #1762770
02/25/15 05:53 PM
02/25/15 05:53 PM
Tulsa, Ok
Tulsa, Ok
Big End width is 1.010, he didn't ask me about the small end width so I'm guess standard... so I'll have to check/measure that.
There is only .179 of material above the pin, including he bushing (had to have that info for Diamond custom piston order). I thought that was very thin too but they assured me it will be more than enough for 1,500hp.
They did say they have made this same rod for Muscle Motors with great success.
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762771
02/25/15 06:01 PM
02/25/15 06:01 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know what is thick or not, but my Howard's steel rods are 0.225" above the pin.
I forget, but is 1.010" Mopar width instead of BB Chevy width?
Re: Very nice set of R&R custom rods I just received [Re: 440Jim] #1762772
02/25/15 06:09 PM
02/25/15 06:09 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Check them out before using. Ryan at Shadydell purchased a set for 501 cid small block.
The small ends were not machined straight.
Matt
Re: Very nice set of R&R custom rods I just received [Re: 440Jim] #1762773
02/25/15 06:13 PM
02/25/15 06:13 PM
Tulsa, Ok
Tulsa, Ok
Jim, I'll try to update the picture you created years ago. Can you add the info on your Howard rods?
I remember him telling me that the H-beams were .100 wide but I'll check.
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762774
02/25/15 06:17 PM
02/25/15 06:17 PM
NC
440Jim Offline
440Jim  Offline
NC
My Howard's rods are "billet" I-beams, not H-beams like the rest. The pin end of mine are 1.061" which is narrower and lighter than the SCAT H-beams I had in my old 511 engine.
Re: Very nice set of R&R custom rods I just received [Re: 440Jim] #1762775
02/25/15 08:52 PM
02/25/15 08:52 PM
Q
Quicktree Offline
Quicktree  Offline
Q
they look chinese to me
Re: Very nice set of R&R custom rods I just received [Re: Quicktree] #1762776
02/26/15 01:00 PM
02/26/15 01:00 PM
Tulsa, Ok
Tulsa, Ok
Eagle & R&R comparison
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762777
02/26/15 01:01 PM
02/26/15 01:01 PM
Tulsa, Ok
Tulsa, Ok
Eagle & R&R comparison 2
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762778
02/26/15 01:01 PM
02/26/15 01:01 PM
Tulsa, Ok
Tulsa, Ok
Eagle & R&R comparison 3
The H-Beam on the R&R is tapered getting smaller as it reaches the pin, the Eagle is the same size for the length of beam.
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762779
02/26/15 01:39 PM
02/26/15 01:39 PM
NC
440Jim Offline
440Jim  Offline
NC
So that looks like one way they are reducing weight.
Am I reading the paper note correct?
The Eagle has 0.220" above the pin, and the R&R 0.190" (or are they 0.179")
440Jim wrote:
The pin end of mine are 1.061" which is narrower and lighter than the SCAT H-beams I had in my old 511 engine. Which I think were 1.125" wide.
So the R&R are still wider at the pin end, 1.130". That helps support the pin.
Re: Very nice set of R&R custom rods I just received [Re: 440Jim] #1762780
02/26/15 04:22 PM
02/26/15 04:22 PM
Tulsa, Ok
Tulsa, Ok
Yes, when I spoke to R&R about the material above the pin he told me .179 but when I measured I got .190 so maybe the difference is the pin bushing??? when I called him, I'm not sure if he looked on the drawing or went out to the shop and measured the actual rod and they may not have had the pin installed yet..
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762781
02/26/15 05:17 PM
02/26/15 05:17 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
How do they compare to Manley H-beams?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Very nice set of R&R custom rods I just received [Re: WadeMetzinger] #1762782
02/26/15 06:20 PM
02/26/15 06:20 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
Rod 4
nice looking rods! i like the weight specs. you said they were 2.20 but the writing on the paper says 2.35? are they a stocking item or have to special order?
