Polishing anodized trim #1761675
02/23/15 11:16 PM
02/23/15 11:16 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I'm trying to decide if I should just strip the anodizing off some trim and polish it. I figure I can sand it with 1000 grit then polish it. The car is driven in nice weather, anyone done this/have any experience with this?
How did it hold up?
Re: Polishing anodized trim [Re: UCUDANT] #1761676
02/24/15 12:00 AM
02/24/15 12:00 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Which trim is it? Are you sure its anodized aluminum and not stainless? Once you strip the anodizing the aluminum will continually oxidize regardless of how much polishing you do.
Re: Polishing anodized trim [Re: UCUDANT] #1761677
02/24/15 12:31 AM
02/24/15 12:31 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Better to use chemicals to remove the anodizing. You must get ALL anodizing off or the finished trim will look terrible. On all the tight spots it will be hard to get it all off, you will sand too much on the corners and alter the shape, and make thin spots. If you don't believe me, try it on a junk piece first.
Oven cleaner will remove it. Immersing it and soaking it off is bad, you want to leave the anodizing on the backside of the trim, it can corrode and get holes eaten in it where it retains water. Also the anodizing adds strength and rigidity to the aluminum trim.
So use chemicals to remove it on the visible sides only, clearcoat with automotive quality clearcoat it to keep it from going dull.
Re: Polishing anodized trim [Re: NANKET] #1761678
02/24/15 02:41 AM
02/24/15 02:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Anodizing adds as much strength an rigidity as a coat of paint ... none! C'mon, really ... who told you that ?!? Its a coating for cryin' out loud.
Re: Polishing anodized trim [Re: Stanton] #1761679
02/24/15 09:25 AM
02/24/15 09:25 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Anodizing does make the surface of the part harder but does not make the part significantly stronger.
"I think its got a hemi"
Re: Polishing anodized trim [Re: gdonovan] #1761680
02/24/15 12:32 PM
02/24/15 12:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not regular clear or color anodizing. Only "hard anodizing" makes the surface harder. Hard anodizing has no color pigment and would be used on wear surfaces - much like "hard chroming" steel. Neither are meant to be pretty.
http://www.anodizing.org/Anodizing/benefits.html
Re: Polishing anodized trim [Re: Stanton] #1761681
02/24/15 01:14 PM
02/24/15 01:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And once you remove the anodizing and polish aluminum it will scuff very easy,clear coat helps but eventually it goes away depending on what conditions it is exposed to.
Re: Polishing anodized trim [Re: UCUDANT] #1761682
02/24/15 02:00 PM
02/24/15 02:00 PM
pa.
dan9 Offline
dan9  Offline
pa.
I have done it many times. Easy-off oven cleaner will remove it. Mask off any painted areas. You can't just remove it from small areas because it will not feather or blend in. As others have mentioned I usually hose it off after 15 or 20 mins. Then you can do straightening or fixing dents. I have an old refrigerator motor with a buffing pad and the various compounds. I have found with this set-up I can finish sand with worn-out 400 grit and polish buff with the white compound and get great results. It is true it will scratch easier without the anodizing. The anodizing was put on to protect it from the abuses of daily driving. I polish mine once a year Simichrome from a motorcycle shop and it looks better to me than ones that have a coating. I thought it would oxidize over time winters but that has never happened to me. I would think with 1000 grit and something like Simichrome you will be happy.
Re: Polishing anodized trim [Re: dan9] #1761683
02/24/15 11:04 PM
02/24/15 11:04 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
If one wanted to have aluminum trim reanodized who would be a good source?
Re: Polishing anodized trim [Re: 340cpe] #1761684
02/24/15 11:20 PM
02/24/15 11:20 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
shine on me norm does nice work
shineonmetrim.com
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Polishing anodized trim [Re: 1969gtx] #1761685
02/25/15 09:40 AM
02/25/15 09:40 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks to all
Re: Polishing anodized trim [Re: UCUDANT] #1761686
02/25/15 05:44 PM
02/25/15 05:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I stripped my grille with Easy Off, wet sanded and polished. Been like that for quite a few years. Used Mothers Aluminum Polish and touch it up about once a year on top. Anodized doesn't shine as well.
Re: Polishing anodized trim [Re: GY3] #1761687
02/25/15 09:50 PM
02/25/15 09:50 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I think I have my solution
Re: Polishing anodized trim [Re: UCUDANT] #1761688
02/25/15 11:51 PM
02/25/15 11:51 PM
sandbagger Offline
sandbagger  Offline
Anyone repainted the black accents on the grilles after striping the anodizing?
"Hemmings Liftoff Hood Cover Bee"
"63 Savoy Max Wedge"
Re: Polishing anodized trim [Re: sandbagger] #1761689
02/26/15 01:13 AM
02/26/15 01:13 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yes, what would you like to know ???
Re: Polishing anodized trim [Re: screamindriver] #1761690
02/26/15 01:38 PM
02/26/15 01:38 PM
sandbagger Offline
sandbagger  Offline
What paint are you guys using after stripping the anodizing?
Colin thanks for the PM!
Re: Polishing anodized trim [Re: sandbagger] #1761691
02/27/15 01:10 PM
02/27/15 01:10 PM
pa.
dan9 Offline
dan9  Offline
pa.
I don't use any coating over the polished areas. Polishing it once a year makes it look better than anodized stuff. I think it would dull it with clear.
Re: Polishing anodized trim [Re: dan9] #1761692
02/28/15 09:55 PM
02/28/15 09:55 PM
MD
p d'ro Offline
p d'ro  Offline
MD
Agreed, don't clear. It doesn't adhere to metal well and will peel, making you redo. Stripping anodizing is a PITA, but I did it on the hood lip and headlight surrounds on my 67 rt six years ago, fixed dings, sanded and polished. The sanding was a [Edited by Moparts - Family Friendly Site - Keep it clean]. Ended up with tommy John surgery ask I needed to do it by hand. Went 600, 800, 1000, 1500, then rouge... all trim wanted over a grand.. I love it better than the dull look, but not OEM show..
