Re: Polishing anodized trim
[Re: gdonovan]
#1761680
02/24/15 12:32 PM
02/24/15 12:32 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Anodizing does make the surface of the part harder
Not regular clear or color anodizing. Only "hard anodizing" makes the surface harder. Hard anodizing has no color pigment and would be used on wear surfaces - much like "hard chroming" steel. Neither are meant to be pretty.
http://www.anodizing.org/Anodizing/benefits.html
[Re: 340cpe]
#1761684
02/24/15 11:20 PM
02/24/15 11:20 PM
Posts: 643 southern conn
1969gtx
southern conn
shine on me norm does nice work shineonmetrim.com
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: UCUDANT]
#1761686
02/25/15 05:44 PM
02/25/15 05:44 PM
Posts: 4,672 Wichita
GY3
Wichita
I stripped my grille with Easy Off, wet sanded and polished. Been like that for quite a few years. Used Mothers Aluminum Polish and touch it up about once a year on top. Anodized doesn't shine as well.
[Re: screamindriver]
#1761690
02/26/15 01:38 PM
02/26/15 01:38 PM
Posts: 983 Michigan
sandbagger
What paint are you guys using after stripping the anodizing? Colin thanks for the PM!
"Hemmings Liftoff Hood Cover Bee"
"63 Savoy Max Wedge"
[Re: dan9]
#1761692
02/28/15 09:55 PM
02/28/15 09:55 PM
Posts: 1,584 MD
p d'ro
MD
I don't use any coating over the polished areas. Polishing it once a year makes it look better than anodized stuff. I think it would dull it with clear.
Agreed, don't clear. It doesn't adhere to metal well and will peel, making you redo. Stripping anodizing is a PITA, but I did it on the hood lip and headlight surrounds on my 67 rt six years ago, fixed dings, sanded and polished. The sanding was a [Edited by Moparts - Family Friendly Site - Keep it clean]. Ended up with tommy John surgery ask I needed to do it by hand. Went 600, 800, 1000, 1500, then rouge... all trim wanted over a grand.. I love it better than the dull look, but not OEM show..
