Front Shock Mounting Hardware
#1761311
02/23/15 01:04 PM
02/23/15 01:04 PM
Posts: 36 Enid,OK
Husker67
Enid,OK
Just a quick question regarding the upper shock mounting hardware on a 67 Coronet. I am trying to finish up the front suspension and am in the process of installing the shocks. The FSM shows a top washer, the rubber bushing with metal insert, and then a lower washer. I don't recall there ever having been a lower washer during disassembly and there wasn't one included with the new hardware that had been ordered. Having said that, it has been approximately 8 years since I disassembled the front end and my memory may be fuzzy? Was a lower washer installed during assembly and lost during a subsequent shock replacement? If so - would anyone know who might sell the correct washer? Thanks for any help you can offer...
67 Coronet 500 - restoration in progress
Re: Front Shock Mounting Hardware
[Re: Husker67]
#1761312
02/23/15 08:45 PM
02/23/15 08:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Well, there should be a lower washer there, as for who sells the correct one. I dunno? I am not into that kind of thing myself, the resto forum might be a better place to find out that one.
[Re: ahy]
#1761314
02/23/15 11:34 PM
02/23/15 11:34 PM
Supercuda
About to go away
About to go away
up yours
Note his sig
Don't think he wants just any old washer, which would work, but not be correct.
[Re: Husker67]
#1761316
02/24/15 11:48 AM
02/24/15 11:48 AM
Posts: 36 Enid,OK
Husker67
Enid,OK
Thanks guys - I figured that there probably was one but I would have figured the hardware and mount kit I had purchased would have included it. I will see what I can come up with through Bill Rollick or one of the other suppliers.
