Re: 360 Dodge Backfiring
[Re: Frankenstein360]
#1760742
02/22/15 10:03 PM
02/22/15 10:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Find the leak, spray WD40 around that side of the intake.
You may also be running a bit rich, but that's not likely your misfire problem. I'm thinking a vacuum leak primarily because you say it is not there with the choke on (which richens it up) then comes on when the choke is off (leans out).
#1760744
02/22/15 11:11 PM
02/22/15 11:11 PM
RapidRobert
Welcome aboard . the black smoke on initial startup I'm thinking not enough "choke pulloff" distance. Vacuum (elec choke) or pull the cable a bit (manual choke) is supposed to open the choke plate a bit from "all the way closed" when it starts. A seperate issue, As SC said are you hearing it in the carb or the ex (on the one side)? OK when enriched but not when choke off says vac leak to me. You might block both metering rods "up" when warmed up & see if it is OK or not which just further says vac leak to me.
#1760746
02/23/15 12:23 PM
02/23/15 12:23 PM
Supercuda
About to go away
About to go away
up yours
Now that you have the leak fixed we can look at the rich issue. As long as it's not caused by the choke being on too long. Rest your idle mixture using the best vacuum method. This will be a balancing act between idle mixture, idle speed and base timing. Once that is good then test drive it for a bit to see if that's all you need. It may very well be adjusted too rich to compensate for the leak you fixed. If that cures your problem we are done, if not then we can fool with jets and such later.
Out of curiosity, where are you pulling your brake vacuum from? the #7 runner? or the back of the carb?
#1760747
02/23/15 01:51 PM
02/23/15 01:51 PM
RapidRobert
What can I do to get more torque out of it cause it's in a hill long truck and need some more oomph instead of hp? I'm on a budget tho
You might dial in the dist subsystems in order & if you want to pull the dampener/tchain cover then replace the timing set with a multiple keyway set & adv it 4 deg (OE '82 low comp 360 I'm assuming) & if you do that do it first then the dist work. I'm assuming the AFB ain't lean. Actually the worst area is likely the exhaust but that'd be a bit pricey. EDIT missed that you have headers, so I'm assuming your muffs are fairly low restriction units. You might need a strip kit for the AFB
#1760749
02/23/15 08:10 PM
02/23/15 08:10 PM
Supercuda
About to go away
About to go away
up yours
So, was the misfire coming out the driver's side exhaust? Probably #7 cylinder was lean due to the leak you found. As for 2nd gear, check the obvious, fluid level all warmed up and in neutral, not park. If that is good, then adjust the front band. If that fails, well it might be a sticky apply servo. If not rebuild time. You do have the kickdown linkage installed and working right? Front band adjustment https://www.youtube.com/watch?v=z166OBLOVAQRear band adjustment https://www.youtube.com/watch?v=Aci45eVwGJY
#1760751
02/24/15 05:34 PM
02/24/15 05:34 PM
Supercuda
About to go away
About to go away
up yours
The front band is fairly easy to adjust, no need to drop the pan. The video is pretty good on how to adjust it. If you do not have a torque wrench that reads 72 in/lbs Harbor Freight sells them for less than a shop would probably charge you to do it.
If it's not low on fluid and the band adjustment doesn't fix it, then you will need a trans shop.
