Re: No pedal after burnt clutch
[Re: jimmy]
#1760691
02/22/15 06:59 PM
02/22/15 06:59 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
My . You need a NEW clutch assembly. Disc, Pressure plate, throwout bearing, and maybe the flywheel resurfaced while you have everything torn down. Too much work to cheep out on replacing only one item with the hopes that it will work when back together. Again my . Good luck
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
