Tandem Axle 1-ton - Bueller? Anyone here?
#1759892
02/21/15 08:57 PM
02/21/15 08:57 PM
Posts: 1,379 Tennessee
WyleECoyote
Tennessee
I haven't spent much time over here in the Truck Forum, so I thought I'd ask if anyone here has ever added second axle and posted their build up. I've found this one local - and I'm really, really hooked on the look; sans fuel tank. I'm set to look at it this week, but not sure about how they added the second axle. Its just a roller axle, coil springs are missing in the picture but thats what he used. I appreciate any suggestions, tips, or comments; negative, neutral, or positive. Thanks!
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Tandem Axle 1-ton - Bueller? Anyone here?
[Re: WyleECoyote]
#1759894
02/21/15 11:47 PM
02/21/15 11:47 PM
Posts: 2,146 Byron, NY
W.I.N. Racing
Byron, NY
The second axle is only for looks, DOT will fine the itshay out of you if you are loaded more than the factory rating. also the rear brakes must be functional.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1759896
02/22/15 12:51 AM
02/22/15 12:51 AM
WyleECoyote
Tennessee
Why do the rear brakes on axle two need to be functional? My tandem axle car trailer only has brakes on one axle.
[Re: 440newport]
#1759897
02/22/15 12:54 AM
02/22/15 12:54 AM
WyleECoyote
Tennessee
I've seen some 6x6 trucks done using a transfer case that has 2 rear outputs. I would love to build one some day.
Albeit cool to have two power rear axles, I'm fine with one; I just really dig the tandem axle semi truck look!
[Re: WyleECoyote]
#1759898
02/22/15 01:46 AM
02/22/15 01:46 AM
Posts: 1,728 Chicagoland
Cooter
Chicagoland
Because the second axle takes some of the load off of the original rear axle, giving it less traction and making it easier to lock up.
[Re: WyleECoyote]
#1759899
02/22/15 09:34 AM
02/22/15 09:34 AM
Posts: 6,033 Greenville, PA
redraptor
Greenville, PA
Legal where you are but not in this commonwealth.
[Re: 440newport]
#1759900
02/22/15 10:01 AM
02/22/15 10:01 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
That is my friend Mikel's M715. I've driven that, it is beastly.
[Re: 440newport]
#1759901
02/22/15 12:37 PM
02/22/15 12:37 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I've wanted to build a tandem 1 ton since before I could drive. Where can I find the transfer case to do this? The rest I can fab.
