I am Restoring a 71 cuda 4 speed built nov 70. numbers matching, all original sheet metal. I am at the point of putting parts back on the car, I have two different dash reverse light harnesses, one has a larger grommet than the other. I went to match it up to the hole in the fire wall....next to bulk head, but there is only the original "dimple". I did have to weld some holes up on the fire wall, I "knew" were not in factory locations. But now I'm wondering if there is a "other" location for this wire? Any help/pictures would be appreciated. Thanks Moparts for the posting.
TIA
Ron
