Long Dowell Pins #1758837
02/19/15 10:53 PM
02/19/15 10:53 PM
Dyno1 Offline OP
Dyno1  Offline OP
Who makes the long dowell pins for using a mid plate. Need a pair of pins 1-1.25" long. Mopar pins are .495 diameter, GM pins are .500 and will not work. Thanks, Dyno
Re: Long Dowell Pins [Re: Dyno1] #1758838
02/19/15 11:16 PM
02/19/15 11:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: Long Dowell Pins [Re: Dyno1] #1758839
02/19/15 11:18 PM
02/19/15 11:18 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'm cheap
Bought myself some 1/2" steel rod, cut it to the desired length, chucked it up in the drill/press and hit it with some sand paper and made it .001" interference. Also gave myself a generous radius on the trans side and that sure helped with R&R's
Your mileage may vary
Re: Long Dowell Pins [Re: Dyno1] #1758840
02/19/15 11:54 PM
02/19/15 11:54 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
Check big block Ford. They are the Same id, but I don't remember how much longer they are.
Re: Long Dowell Pins [Re: roadhazard] #1758841
02/20/15 12:17 AM
02/20/15 12:17 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Good deal roadhazard...I'm going to toss that into file 13 for future reference...
...FAFO...
Re: Long Dowell Pins [Re: NITROUSN] #1758842
02/20/15 02:50 AM
02/20/15 02:50 AM
Dyno1 Offline OP
Dyno1  Offline OP
Try Robb http://www.robbmcperformance.com/products/dowels.html
Don't need offset pins like for a 4 speed. Just longer pins. thanks, Dyno
Re: Long Dowell Pins [Re: mercman1] #1758843
02/20/15 03:11 PM
02/20/15 03:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , they are not , Lakewood passes them off as the same but they are not. Ford is .500 , Mopar is .495 , .005 is to much of an interference fit addition.
Go to Home Depot and get a piece of their 1/2" steel dowel stock , usually just under .500 and do as roadhazard suggests if you don't have access to a lathe ...
