01 dodge deisel broke 5th gear again #175881
12/26/08 11:33 PM
12/26/08 11:33 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Is there a problem with these transmissions? It has 40k since this broke last time and it may have had an upgraded gear installed then. Cant remember what it had though. Any ideas to make it last longer? The edge chip probably overpowers the trans I'm thinking. Help?
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: 01 dodge deisel broke 5th gear again [Re: EV2CUDA] #175882
12/26/08 11:55 PM
12/26/08 11:55 PM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
If your trans. is a 5 speed, its pretty common. Not enough transmission for the motor. I broke my trans. (different gears & shafts) including the 5th gear 4 times before I bought another transmission. Had I known then what I do now, I would have switched over to a 6 speed like whats in my 03 truck now. I put the upgrade parts for the 5th gear in but the simple fact is that the 5 speed belongs in a car, not behind a Cummins.
New transmission & parts - www.blumenthalmfg.com in Olahoma City, OK.
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175883
12/27/08 12:08 AM
12/27/08 12:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Not true. There are up grades that make it survive. There are many that are worked and they dont fail. Plus there is a lot of hack fixes and misconceptions on what is really going on.
http://www.torqueking.com/torque%20king%20nv4500.htm
http://www.quad4x4.com/NV4500%205th%20Gear%20Failures%20and%20Solutions.htm
Re: 01 dodge deisel broke 5th gear again [Re: EV2CUDA] #175884
12/27/08 12:10 AM
12/27/08 12:10 AM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
There are several fixes for the 5th gear problem in those trucks.
There is a better shaft for one. Some guys weld the gear on the shaft.
In general, I've been told it fails more often in trucks who have a driver who drives with it in 5th below 1500 rpm.
Re: 01 dodge deisel broke 5th gear again [Re: NITROUSN] #175885
12/27/08 12:22 AM
12/27/08 12:22 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
You cant gross 19 - 26K consistently day in & out or at least once a week with a 5-speed no matter what you put in it....mine broke twice not pulling a trailer! I used to Hot Shot for a living with the other truck with the 5-speed and anyone who pulls a trailer professionally will tell you that 5 speeds are junk. The transmission is under rated for the truck & the Cummins and by the time you spend all of the money and time on trying to upgrade a 5-speed, you could have had a new 6 speed transmission & new front driveshaft for about $2500.00 and not sink money into a black hole of a transmission.
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175886
12/27/08 12:39 AM
12/27/08 12:39 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You cant gross 15 - 26K with a 5-speed no matter what you put in it....mine broke twice not pulling a trailer! I used to Hot Shot for a living with the other truck with the 5-speed and anyone who pulls a trailer professionally will tell you that 5 speeds are junk. The transmission is under rated for the truck & the Cummins and by the time you spend all of the money and time on trying to upgrade a 5-speed, you could have had a 6 new speed transmission & new front driveshaft for about $2500.00 and not sink money into a black hole of a transmission.
That may be true in some cases buy the fact is there are fixes that work. Granted new and improved transmissions should be better. The main problem is mis-conception. Putting a fix on something that should be replaced. In a nutshell if you had the hack fixes you should of had a new mainshaft. That does not mean the rest is junk. I owned and ran a dealership and I know what came into our shop and the 4500 failures were almost non-exhistant. Point here is the poster needs advice and all advice is good once you sort through the myths.
Re: 01 dodge deisel broke 5th gear again [Re: NITROUSN] #175887
12/27/08 01:07 AM
12/27/08 01:07 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
I wasn't trying to get into a pissing match with you, I was just trying to point out the 5 speed is only rated for about 19,000 lbs and Chevrolet used to use the very same transmission with the Chev. mods. made to them and they had more trouble with them than most people knew about.
We used upgraded parts in the 5 speed and it was professionally built but one tranny breakdown cost me time lost for work and the repairs so I have no faith in the 5 speeds anymore. My 6 speed weighs twice as much as my 5 speed, the internal parts are engineered better. The newest latest & greatest shafts, gears, bearings, etc. may be better but for the guy looking for a solution for his tranny that broke twice now, he may want to consider the newest parts from the sites you posted but I bet he has burned a bunch of money already on previous repairs and might be hesitant to sink more money in the 5 speed. I'd rather have my 6 speed going up a mountain in Colorado or Pennsylvania with a trailer or without. I LOVE my 6 speed.
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175888
12/27/08 01:18 AM
12/27/08 01:18 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I hear you. I use my 95 3500 4x4 dump and commonly pull 21,000 to 22,000 on the trailer. I also had a 96 v-10 wrecker that did the job.
To each their own and I understand when the truck is down and your lively hood is at stake that staying on the road is a priority.
Either way the poster got some poop to go by.
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175889
12/27/08 01:18 AM
12/27/08 01:18 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
My buddy had a 2001 with a 5 speed and beat the snot out of it daily , had very few issues of any kind ..It ALWAYS had a 1000 lb bobcat welder in the back , and most often it had a trailer with 5000 lbs of steel on (he built high class steel fencing for rich people)
When he was on off hours he was pulling his 28 foot enclosed with his dirt cars and again, loaded heavy
Again let me stress ,he worked this truck hard
countless times, I ASKED him about 5th gear
he would tell me to shut up
well, at about 335,000 it spun the gear off
He fixed it himself, welded it on !
Sold the truck this spring with 385,000 on it
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 01 dodge deisel broke 5th gear again [Re: bigdad] #175890
12/27/08 01:38 AM
12/27/08 01:38 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
He sounds like one of the lucky ones. A LOT of trouble issues can be attributed to the drivers of some of these trucks. I used to pick up my loads in Elkhart, IN and that's the Hot Shot transport capital in the country....there are several truck & trailer shops up there and unfortunately when riding by some of these shops, there were more Dodge's in the lots than Ford's. One day while in one of the shops, after a couple of years of pulling, I asked why do I see so many Dodge trucks parked and was told that a lot of them were in for performance upgrades, normal repairs/maintenance or automatics & 5 speeds were out....didn't want to hear that.......
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175891
12/27/08 01:58 AM
12/27/08 01:58 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
PS - Regular fluid changes with Mopar fluid are highly recommended on both 5 & 6 speeds....cheaper than repairs & down time! Pulling the PTO plate(s) off while changing the fluid is a good idea too so as to check for any broken teeth or misc. parts laying in the bottom of the gear box!
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175892
12/27/08 02:12 AM
12/27/08 02:12 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
His theory was he didn't lug it , I don't know how much truth to that there is ?
Good ol pickup, she was at that point though where things were about to start wearing out
Re: 01 dodge deisel broke 5th gear again [Re: bigdad] #175893
12/27/08 02:47 AM
12/27/08 02:47 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
Good theory as I have been told the very same thing! It's one of the worst thing to do to the tranny.
Re: 01 dodge deisel broke 5th gear again [Re: E-Ticket] #175894
12/27/08 09:17 AM
12/27/08 09:17 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My boss had a '97 with a 5 spd, at around 200,000 it lost 5th. I pulled the tailshaft housing pulled the old nut and washer out and told him to go down to the dealer to get new ones.
He took the gear with him and they sold him the gear, washer and nut. I made him take the gear back as there was just normal wear on his old one. I reinstalled gear, locktited,torqued, and staked the nut. Filled the case with Mobil one gear lube. When he traded it off it was still going strong. Dave
Re: 01 dodge deisel broke 5th gear again [Re: quickd100] #175895
12/27/08 09:45 AM
12/27/08 09:45 AM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
What part actually breaks? I checked the old bill and all the parts were oil gear and nut. I want to do it my self this time.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: 01 dodge deisel broke 5th gear again [Re: EV2CUDA] #175896
12/27/08 10:18 AM
12/27/08 10:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I have a 95 used only for towing. The 5th gear retaining nut came loose at 35,000 miles. It was upgraded then and now has 165,000 miles. Never had a problem since. A friend of mine specializes in dodge diesel truck hop-ups. He states it is a harmonics issue when this trans is run at low RPM in 5th gear behind a Cummins. This is why during my 26 years as a Chevrolet dealer tech I have not seen a 4500 trans failure. My sons 2000 did break the output shaft. It is hopped up pretty good. However when disasembled the shaft appeared to have been cracked half way thru since new. The crack was dull in color. This occured at 170,000 miles.
Doug
Re: 01 dodge deisel broke 5th gear again [Re: EV2CUDA] #175897
12/27/08 11:28 AM
12/27/08 11:28 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The '99 my buddy in Nebraska had lost the nut the first time. The dealer replaced the nut. Second time it stripped the gear.
He was going to do the 6 speed swap but he already had the truck sold to a friend. After talking it over with the friend they put a rebuilt 5 speed in.
The '99 is still going strong and his '04 has been trouble free.
Re: 01 dodge deisel broke 5th gear again [Re: EV2CUDA] #175898
12/27/08 11:33 AM
12/27/08 11:33 AM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Check out QuickD100's reply. Its really an easy fix, I've done quite a few of them.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 01 dodge deisel broke 5th gear again [Re: EV2CUDA] #175899
12/27/08 11:40 AM
12/27/08 11:40 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You need to read what people post. All you need to know was on the link I posted.
Almost all cases of mainshaft fifth gear failure can be directly attributed to insufficient support for 5th gear. In the classic case, the nut retaining the mainshaft fifth gear backs off allowing the gear to slide back in the transmission extension housing and out of contact with countershaft 5th gear. This failure usually occurs without warning or noise. You are driving happily along in 5th gear, either you (or your cruise control) lets off on the accelerator for a moment. You step on the accelerator to resume speed and the engine races, but your transmission is no longer transmitting power! White faced and shocked, you mutter “what the #%!!” as you check to make sure the shifter is still in fifth, then downshift to fourth and let the clutch out. Your truck responds instantly as power is returned to the rear axle. Your blood pressure lowers a bit and you try to upshift to 5th. Again no power and no noise. You mutter “Oh no, I lost fifth gear!” Back into fourth and away you go wondering if you are going to make it home and HOW MUCH IS THIS GOING TO COST ME TO FIX!
Typical 5th gear failure on a stock NV4500HD transmission. Note the reddish/orange sludge discoloring the shaft. This is a sign of wear or “fretting”. What you see is actually oxidized metal particles worn from the gear and shaft. Vibration and cyclic loads are the main causes of fretting.
Every time someone tells me “I lost 5th gear”, I am reminded of an occurrence in my youth. I was riding to school on a Brockway school bus. We had a lady bus driver who was a chronic gear grinder. One morning, when she was unable to force the transmission into fifth gear, she radioed the school that “I lost 5th Gear”. The reply was something to the effect “Wh’ad ya do drop it on the ground?”. I presume she had little solace with that reply, but she bravely continued on in 4th gear and we all eventually arrived at school. Like my bus driver, you too will probably also make it to your destination after your 4500 turns itself into a 4 speed because this type of failure normally does not cause incapacitating damage in the short term. Chances are, what occurred inside your transmission was simply the 5th gear wore into the mainshaft. Once the gear is loose, it will work the nut off until the gear slides back and your day is ruined.
Nut Woes: Band-Aid Approach to A Serious Problem
The initial attempts to prevent 5th gear failures focused on the retaining nut which was a flat nut without a lockwasher in the original configuration. New Venture first added a lip on the nut that could be crimped into a keyslot, then a concave spring lockwasher, and lastly a split nut with a crossbolt to increase the thread contact. The aftermarket weighed in with at least two styles of nuts with set screws. Several chemical thread locking compounds have also been tried. None of these “fixes” were successful in keeping the gear on the shaft. They failed because they address a consequence of the failure instead of the cause. (To find out the reasons why, read on.)
Clockwise from top left: flat nut, concave washer, crimp lock nut, crossbolt lock nut, aftermarket nut with 2 setscrews, aftermarket nut with 3 set screws and brass pads.
Overloading Aggravates Problem
Before discussing the problems associated with factory partial spline and aftermarket full spline mainshaft designs, I want to point out that they are good quality parts made by reputable manufacturers. The 5th gear failings they have are not metallurgy or workmanship related. Shaft wear and gear failure is primarily due to design, but diesel engine harmonics, and overloading also are significant factors. Owners of diesel powered NV4500 equipped trucks often greatly exceed the recommended horsepower and load ratings for their vehicle. We have seen these trucks with engines putting out over 500 horsepower and 1,000 ft-lbs. of torque. We have also seen combined truck and trailer weights exceeding 40,000 lbs.. Now, when you consider the NV4500 is rated for up to 460 ft-lbs. of torque and 19,000 lbs. combined truck and trailer weight, you can see why part of the responsibility for transmission problems must rest on the shoulders of truck owners who grossly exceed the vehicle design limits and insist on making their ¾ or 1 ton work like a 2 or 3 ton truck
Mainshaft Types and Weak Points
To support the 5th gear, the factory mainshaft has both a splined area to transmit torque and a smooth machined surface for the fully internal splined gear to press onto. The end of the mainshaft is drilled and tapped for a pull rod so the gear may be pressed on the shaft without damaging other components inside the transmission. With this type of shaft, only the tips of the gear splines are in contact with machined support surface of the shaft. This area is also directly under the gear teeth. Over time, the gear splines will actually wear into the shaft. As this wear continues, the fit between the gear and shaft becomes progressively looser. At this point, every time you accelerate or decelerate in fifth gear, the gear moves back and forth between drive and coast. This back and forth motion against the nut is what eventfully causes the nut to back off. Since the mainshaft bearing is inboard of the gear, the transmission will usually operate in all other speeds.
Stock New Venture mainshafts from Dodge NV4500HD transmissions.
The top shaft had the typical fifth gear failure. The splines are worn and you can see the wear marks in the support surface to the right of the splines.
The lower shaft is a new takeout in perfect condition. Note, the support surface is smooth
The aftermarket introduced two types of imported mainshafts with near full length splines in an attempt to remedy the problems experienced with the factory shafts. The splines on these shafts are considered “flexible” in the sense the gear is not supported by pilot rings at either end so it can “flex”, or rock under load. Both styles are used with the same fifth gear design as original equipment. These shaft are most often sold with an aftermarket mainshaft nut that has two setscrews.
First on the market was a shaft with splines that were made to provide a fairly light interference or press fit with the gear splines. This shaft design was introduced by Blumenthal Manufacturing of Oklahoma City. Next on the market was a shaft made for gear wholesaler Midwest Transmission of Zumbrota, MN. With this design, the shaft splines are near full length, but machined to be a slip fit with the gear. This shaft is grooved to allow a 3 piece thrust washer to be inserted between the gear and retaining nut. Both of these shaft designs received tremendous positive press coverage as permanent cures for 5th gear failures and were enthusiastically sold by almost everyone in the transmission repair business including us. Unfortunately, great confidence in these designs has not proven to be fully justified. While the percentage of 5th gear and related failures is probably lower with either full spline shaft design in comparison to the factory shafts, the cold truth is full spline shaft failures are occurring.
With the press fit type full spline shaft, gear failures are identical to the original equipment shaft. In other words, the gear loosens up on the shaft and eventfully works the nut off the threads. To have any chance of keeping fifth gear in place, the press fit between the shaft splines and gear splines with this type of shaft must be quite tight. We rejected nearly 50% of the shafts we bought of this design because they did not provide a tight enough fit with the gear. Long before we ever even heard of any failures with this type of shaft, I discussed the importance of accurate machining with the importer and the need to increase the spline contact to prevent the same types of problems we had with the factory shafts.
Full Spline Shaft with Light Press Fit Splines
The other full spline shaft utilizes a thrust washer between the gear and nut. With this design, I know of no instances were the nut backed off. On the downside, this shaft was designed so the 5th gear will easily slip onto the shaft. This slip fit means the gear and shaft splines may eventfully wear themselves away, at which point you could “lose” fifth even though the nut is still in place. This is a very noisy failure as the spline nubs jump over each other, plus all the worn away spline material contaminates your oil. There is one other major issue with this shaft. A secondary function of the fifth gear is to keep the mainshaft rear bearing tight against a thrust washer. With this shaft design, the loose fitting gear cannot hold the bearing tight. If this bearing is not held tight, it tends to wear into the shaft and thrust washer which increases end-play. Excessive end-play can lead to shifting problems, shaft misalignment, and catastrophic failure. This style of shaft is somewhat weaker than other designs due to the reduced shaft diameter at the thrust washer groove. Breakage is not common, but it does occasionally snap in high load situations. Despite the potential shortcomings, this shaft design is very popular with both professional rebuilders and shade tree mechanics because assembly is fast and easy without any press tools.
Full Spline Shaft grooved for thrust washer.
The Surprise Culprit Is…..
The 5th gear splines used on all NV4500 transmissions are of side fit, involute configuration. Involute splines are self-centering, have curved sides, and offer greater torque-transmitting capacity than any other type. Side fit means only a portion of the flanks of each spline are in contact with the mating spline and it is this characteristic that is culprit #1 in the Case of the Lost 5th Gear.
Side fit, involute splines are widely used and well proven for transmitting inline torque. Common examples include input shafts, output shafts, synchronizer hubs, transfer case chain sprockets, propeller shaft slip yokes, pinion yokes, and axle shafts. This spline style is not often used to transmit torque in applications were the torque input is from the side as is the case of the NV4500 mainshaft fifth gear, unless there is some type of additional support (such as pilot rings) to prevent the gear from rocking on the shaft. None of the previously discussed mainshafts use any type of ring or pilot to prevent axial movements occurring under load although the factory gear does derive some weak support from the unsplined portion of the shaft.
If you take a magnifying glass and view a cross section of a 5th gear pressed on the mainshaft splines, you will clearly see the no-contact areas between the tips of each spline and the root of the matching spline. You can also see how short the contact surface is between mating splines. The 5th gear to mainshaft contact area of the mating splines is less than .040” high. The unsupported, no-contact areas or voids, are greater than 1/2 the distance from the minor diameter of the shaft to the major diameter of the gear. With both the factory and full spline shafts these unsupported areas are where wear and eventual failure begin. Such movement will be minute at first, but over time it will increase as the matching parts wear. To eliminate movement, we must have effective and rigid support for the 5th gear. To do this we need to change the design of the shaft, gear, and retaining nut.
Now, lets turn our attention back to the much maligned factory mainshaft with it’s partial 5th gear spline. These shafts have a spline length of just under ¾”. In addition, for additional gear support there is a smooth machined surface just over 1” long. For manufacturing reasons, there are also reduced diameter areas between the splines and support surface and between these two features and adjacent portions of the shaft. The matching gear (which is also used on both full spline shafts) is 2.25” long with internal splines cut the length of the gear. The gear splines are beveled at each end.
Many people assume New Venture choose partial splines over full splines because it was cheaper. The fact is it is more expensive to make a partial spline shaft. Why? The splines are rolled before the shaft is hardened. After the shaft is heat treated to harden it, the support surface is ground to a very, very precise dimension. New Venture could have saved money by rolling full length splines in the first place. So why didn’t they? Well, I can’t be sure, but a comment made to me by a New Venture engineer about the importance of keeping 5th gear concentric on the shaft had to be a consideration. New Venture tried to use the gear splines pressed onto a smooth support surface instead of pilot rings. This approach is reasonably effective with gas engines and moderate loads. However, with diesels, the engine harmonics and horsepower in heavy duty applications creates loads beyond what this design can handle without wear given the shaft size. With a factory mainshaft and gear, you typically “lose” 5th gear when the gear splines have worn into the shaft to the point where repeated axial gear movement works the nut free. New Venture tried to fix the problem by addressing the consequence (by changing the nut design) of the gear working loose, instead of the cause (insufficient gear support). End result: A big problem and a bad reputation for an otherwise excellent transmission.
Cross-section view of 5th gear pressed over unsplined portion of factory shaft.
Look through magnifying glass and note how splines have already slightly indented shaft when pressed on.
Now, let’s take a look at the press fit, full spline shaft. The theory here is longer splines are better, but the side contact, “flexible” spline with it’s limited spline to spline contact and large unsupported areas makes this design subject to the same types of failure as experienced with the factory mainshaft. Some support can be derived by having a very tight fit between the gear and shaft. However, with the “average” fit, premature failure is a distinct possibility.
The concept of the thrust washer style full spline shaft is simple. The design assumes the gear is going to come loose anyway, so they grooved the shaft to accept a split thrust washer between the gear and nut. With this design the thrust washer will probably keep the nut on. The problem here is the designers concentrated on preventing the nut from backing off and ease of assembly. In this they were successful, however, by making the shaft so fifth gear and the rear bearing would be a slip fit, wear and fretting is almost guaranteed. Result: potential for reduced service life.
Spline Cross Sections Showing Progressive Wear.
(top right) New, unworn involute splines. Note the sides of the teeth are slightly curved. Also note the tips are slightly concave from being roll formed.
(bottom left) Typical wear found on a factory shaft or press fit full spline shaft after the second failure when a gear was just reinstalled to temporarily return the transmission to service. Note the spline is worn almost to a knife edge.
(bottom right) Worn off splines typical of thrust washer type full spline shafts when the gear jumps the splines. The matching gear splines are similarly worn.
Close-up of groove and thrust washer style, full spline mainshaft. One split washer is removed to show detail.
Thrust Washer Style Mainshaft broken off at Thrust Washer Groove
Comparison to Ford ZF42 and ZF47
So far, we have only talked about the NV4500 in GM and Dodge vehicles. How did they stack up against the contemporary Ford ZF42 and ZF47 5 speeds? These transmissions have many durability issues, but “loosing” fifth gear isn’t one of the common ones. Unlike the 4500 with its fixed mainshaft gear and bearing supported countershaft gear, the ZF’s used an extremely tight, press fit between the gear and countershaft with no splines or keys. On the mainshaft, the gear is supported by a two piece bearing. The rear output bearing is outboard of the gear. The bearing is held in place by a snap ring on 4x4 models or the rear output yoke on 4x2 trucks. Since the bearing is outboard of the gear, lateral gear movement is limited. To be sure, most of the Ford Diesels coupled to these transmissions were rather anemic compared to the Cummins, but the fact is the basic 5th gear design was more trouble free than the NV4500.
What Next?
So, you ask “Is there any solution to this #&*! problem besides a different truck and/or transmission?” Well, yes there is. The answer is pretty simple (increase gear support), but it required redesigning the mainshaft, gear, and retention system.
The Challenge
The root cause of NV4500 mainshaft fifth gear failures is simply insufficient support for the fifth gear under real world conditions. The solution is also simple, increase support. To provide a practical and customer installable design at a reasonable cost was the challenge. We also wanted to offer the improved design for all NV4500 transmissions including GM and Dodge light duty models.
New Design Features
First off, we knew we had to use a partial, fixed spline shaft to eliminate the rocking motion of the gear that plagues all previous mainshaft designs. The unsplined area is increased in diameter to a size larger than the shaft splines. This gear design was modified from a full spline to a partial spline. The area without splines is precision machined to provide an “interference” or press fit with the larger diameter, unsplined area on the mainshaft. Depending upon application, the gear may be shorter or longer than stock. The rear gear face for most applications is modified to accept a pilot ring. The rear single lock nut is replaced by either a double or triple nut retaining system. The outer nut is a lock nut. The inner nut may be flat or incorporate a pilot ring depending upon application. On new shafts, a hardened, tanged thrust washer is also used. For retrofit kits, a Belleville spring lock washer is used. We also had to invent several new tools to ease installation. To increase holding power and decrease the chance of vibration induced fretting, we use several Permatex® locking compounds with 3,000-4,000 psi. shear strengths. Our Patented design is known as the Torque King®.
The Patented Torque King® eliminates NV4500 5th gear failures!
A. Longer Splines (left arrow) Shaft Pilot (right arrow)
B. Counterbore under gear teeth (fits A)
C. Inner nut with machined pilot ring
D. Hardened Anti-Rotation Washer
E. Center Nut
F. Outer nut with lip to stake in key slot
Benefits of the Torque King®
What’s all this mean to you? Dependability and reliable performance unmatched by any other NV4500 mainshaft/gear design. With the Torque King® design, the splines have one function and one function only; to transmit torque from the gear to the mainshaft. The gear is supported and kept concentric on the mainshaft, by press fits between the smooth gear bores and supporting rings. With this design, the troublesome axial movements and wear that cause factory and full spline shaft failures are eliminated. Under identical service conditions, a transmission with the Torque King® will provide longer and more trouble free service than any factory or full spline mainshaft. Less downtime and longer life make the the Torque King®the most cost effective way to keep your NV4500 equipped truck in service. Whether you rely on your truck for commuting, work, or touring, you can put your mind at ease about 5th gear failures with the Torque King® the mainshaft and fifth gear system designed and built to last.
With Torque King® matched shaft and gears sets, the splines have only one function: transmit torque. The gear is rigidly supported by pilots. Close-up of Inner Nut shows how pilot ring is machined as part of the hardened inner nut. This ring fits a very accurately machined, matching counterbore in the rear of the gear. Torque King® gears for most Dodge applications use fixed splines with a long pilot ring under the gear teeth and a short pilot on the nut as shown here. GM applications are piloted under the gear teeth only due to design differences on GM NV4500 transmissions.
Torque King® In Vehicle Retrofit Kits
Have an otherwise serviceable NV4500 that just suffered it’s first fifth gear failure? Return your transmission to service without removing it from the vehicle with the Torque King® Retrofit Kit. This unique kit consists of a precision machined steel sleeve that is installed over the worn support surface of your factory mainshaft, a Torque King® press fit gear, double nut package with lockwasher, rear output seal, special tools, several Permatex® products and required tools. The Torque King® Retrofit Kit is the only “fix” on the market that restores the critical press fit between the gear and shaft. Plus, this innovative new kit provides steel support rings for both sides of the gear. The splines are only used to transmit torque. Permatex® Bearing Mount is used to restore the fit of the worn mainshaft splines. This Kit is only recommended for use on a transmission that 5th gear has either not failed or just failed for the FIRST time!
Torque King®
Retrofit Kit for NV4500 Transmissions
(Early NV4500HD Kit shown here)
When NOT to Use the Torque King® Retrofit Kit
If your NV4500 with a factory mainshaft was returned to service after the first 5th gear failure with any combination of factory gear, nut, bearing lock, welding, etc., it will have severely worn splines and excessive bearing end-play. These types of temporary repairs MURDER your transmission and we absolutely do not recommend using our Retrofit Kit under these circumstances as your transmission is in desperate need of a total rebuild. In fact, we won’t even sell you a Retrofit Kit if we know this!
If you have a high mileage transmission with 150,000 miles or more, we recommend you have it rebuilt instead of installing the Retrofit Kit. High mileage transmissions usually have excessive end-play which is a good indication the useful service life of the bearings is about over.
The Torque King® Retrofit Kit is only compatible with genuine New Venture original equipment mainshafts. It will not work with any aftermarket shaft of either full or partial spline design!
REFERENCES
An excellent reference for mechanical design and manufacturing is the Machinery’s Handbook published by Industrial Press, 200 Madison Ave., New York, NY 10016. Phone: 1-888-528-7852. We derived much of the information we used in identifying the reasons for fifth gear failures and in the invention of the Torque King® from this source.
Instruction Sheet K6855309 from the Chrysler Motors Mopar Parts Division dated 7/1/98 and revised 9/23/98 details the service procedure for the clamp mainshaft nut in “repairing” fifth gear. The following statement appears: “Caution: if fifth gear nut has backed-off in operation, then fifth gear replacement is also required with fifth gear nut.”. No mention was made about mainshaft wear or the chances this “fix” would hold up when installed on a worn out shaft.
Two interesting back-to-back articles appeared in the Turbo Diesel Register on this subject in issues 30 (pg.36) and 31 (pg. 23). These articles were major factors in acceptance of the thrust washer design, full spline shaft as the end-all cure for 5th gear failures. The full spline shaft sold by Standard Transmission Transmission and Gear Company of Texas was a major topic of both articles. We purchased one of these shafts from Standard Transmission in 2002 which is identical to the shaft imported by Midwest Transmission. The shortcomings of the thrust washer design full spline shaft that we detailed in our discussion above were not readily apparent when these articles were written. For reprints, Contact TDR at 770-886-8877. Address: 1150 Samples Industrial Drive, Cumming, GA 30041. On the web: turbodieselregister.com.
An article I wrote on Catastrophic Manual Transmission Failures appeared in issue 44 of the Turbo Diesel Register starting on page 142. To view a generic version of this article, click here: Causes of Manual Transmission Failures.
