Page 2 of 6 1 2 3 4 5 6
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758571
03/04/15 08:37 PM
03/04/15 08:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
10-4, I seem to recall something about possible wire corrosion by the battery, as that's where the computer is. Though it might be FWD vehicles of that era I am thinking of. Not trying to steer you wrong, but it's been a while.
Try wiggling the wiring around and see if the signal changes, that would indicate an intermittent issue.
I browsed Rockauto to see if they had a computer for you, no California emissions with an auto listed. They have Cal with a stick and Federal for both.
Don't be the exception.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Supercuda] #1758572
03/04/15 10:58 PM
03/04/15 10:58 PM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
that TBI setup is the WORST fuel induction Mopar ever used, except maybe the late 80s jeep RENIX (and only because I have zero experience with the Renix, just "heard about" them)
I can even deal with Lean burn easier.
About to do a motor swap into my son's 89 Ramcharger, just trying to decide WHICH 4 barrel to blow the dust off of among a few choices of on hand carbs...
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Supercuda] #1758573
03/04/15 11:14 PM
03/04/15 11:14 PM
San Diego
Instigate Offline OP
San Diego
For sure. I was looking at NAPA and they've got one for me for 214 after the core. I was so hoping it was some short I missed when I went through the whole harness while the engine was out. But it's looking like it might be the computer I think. I don't see why it would throw that code when I'm getting good readings from the sensor all the way to the computer. Unless it's an intermittent thing like you said. But I don't think it is because it seems to be constant. Never runs perfect.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: volaredon] #1758574
03/04/15 11:20 PM
03/04/15 11:20 PM
north carolina
d100dragracer Offline
north carolina
I agree totally. Im much much happier with a carb and Performer intake now than the TBI a lot more power and the fuel mileage is why better so much more reliable than before all wins switching to a carb. There is no way to make the power you can get from a carb using a TBI and the stock TBI intake they were junk. Mainly because of the junk wiring harness but it was never going to make any power no matter what.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758575
03/04/15 11:22 PM
03/04/15 11:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure what your options are, I hesitate to suggest running a federal spec computer as I do not know what, if any, difference it'll be. I guess all you can do right now is open it up and look closely at it. I have seen circuit boards crack across foil runs printed on them, I just solder a jumper across the crack.
as for you guys suggesting a carb, he's in California, that will not fly.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Supercuda] #1758576
03/04/15 11:33 PM
03/04/15 11:33 PM
San Diego
San Diego
For sure, that's my next step. Would be nice if it was just a blown capacitor or something I can fix on the circuit board. I fixed my video card on my computer by replacing the capacitor that was blown.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: d100dragracer] #1758577
03/04/15 11:33 PM
03/04/15 11:33 PM
San Diego
San Diego
I don't need to hear every guy that has given up on fixing their TBI the right way. I need helpful input on how to diagnose this, not just give up and throw a carb on it.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Supercuda] #1758578
03/04/15 11:36 PM
03/04/15 11:36 PM
San Diego
San Diego
I could put 360 heads, intake, throttle body and computer on tho, ya?
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758579
03/04/15 11:37 PM
03/04/15 11:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One other thing, i forget if I mentioned this, but, my bud's 89 Ram had driveability issues, I forget what they were exactly, but it turned out to be a crack between the exhaust crossover and the plenum of the intake. But I am pretty sure a TPS code was not one of the symptoms.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Supercuda] #1758580
03/05/15 01:38 AM
03/05/15 01:38 AM
San Diego
San Diego
I pulled the computer and took it apart. Nothing visually wrong. I knew it was a slim chance I would be able to see anything. Not sure where to go from here. I guess I'll put it back together and do that test drive I was going to do with the fuel pressure gauge hooked up and make sure my pump is giving good pressure all the time.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758581
03/05/15 08:07 PM
03/05/15 08:07 PM
San Diego
San Diego
So I drove it with the fuel gauge hooked up and it's got good pressure at all times never drops. Is there anything I can do to be sure it's the computer? The TPS code didn't come back yet but I think I just didn't drive it enough for the code to trip yet.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758582
03/05/15 08:11 PM
03/05/15 08:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Codes that set do not instantly clear even if the cause goes away, so it's possible you had an issue testing the TPS that set the code and when you pulled the computer is did a reset. I assume driveability is still the same?
I almost wonder if your EGR isn't leaking by causing this, similar symptoms. Can you block it off for testing purposes?
Did your vacuum readings ever stabilize?
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Supercuda] #1758583
03/05/15 09:04 PM
03/05/15 09:04 PM
San Diego
San Diego
The code reset because I removed the computer and battery. and I didn't test the TPS again after the rebuild until after I saw the code. The driveability is the same, hesitation, stalling when I come to a stop. I tried blocking off the EGR before I did the rebuild but I'll try it again. I'll check the vacuum again. I assumed it was doing that because the timing was off but I shouldn't assume. I'll check it again right now.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758584
03/05/15 09:35 PM
03/05/15 09:35 PM
San Diego
San Diego
Vacuum at idle is vibrating between 17-18hg. I know they reused the valves. Somewhere I read it could be caused by sloppy valve guides.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758585
03/05/15 09:44 PM
03/05/15 09:44 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
How much does the vacuum fluctuate when it stumbles?
- Stu Harmon
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: feets] #1758586
03/05/15 09:47 PM
03/05/15 09:47 PM
San Diego
San Diego
I can't get it to stumble while idleing anymore, it only stalls when I'm coming to a stop while driving. I'll take it for a drive with the vac gauge hooked up.
In park it will rev fine. But when I drive it, it has bad hesitation with some idle fluctuation and will stall when I come to a stop.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758587
03/05/15 09:48 PM
03/05/15 09:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If it only happens every time the vacuum is at a certain point you may be able to chase it down.
- Stu Harmon
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: feets] #1758588
03/05/15 10:14 PM
03/05/15 10:14 PM
San Diego
San Diego
I've never had to check vacuum while driving a vehicle so I'm not sure what is normal. I know it's normal for vacuum to drop when you accelerate but idk how much, anyways. While coasting I get around 19hg with a steady needle. When I stab the gas it drops to 5 or 6 and when it stutters and stalls it drops to nothing.
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758589
03/06/15 08:05 PM
03/06/15 08:05 PM
San Diego
San Diego
A guy on ramchargercentral suggested I should do a compression check. Results are good.
1-130
3-130
5-135
7-135
2-130
4-130
6-135
8-135
Re: 89 318 TBI Freshly Rebuilt Engine Idle Surging / Stalls [Re: Instigate] #1758590
03/06/15 08:20 PM
03/06/15 08:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yep, think you can probably rule out a mechanical issue at this point, at least with the longblock.
Fuel pressure looks good.
How about the ignition system? New, used? wires, plugs, cap, rotor, distributor?
