converter bolts....best method tightening #1757908
02/18/15 06:33 PM
02/18/15 06:33 PM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
got 3 of the 4 bolts in and tight, having trouble with 4th one, do you tighten each one and move to the next one or do you put in a little loose until all 4 are in centered then rotate around and tighten. what is the best method you use, thanks
the more I deal with people the more I like my dog
Re: converter bolts....best method tightening [Re: birdboy] #1757909
02/18/15 06:39 PM
02/18/15 06:39 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I always have to leave them loose then tighten after all are in. Get them close to tight as if to much is sticking out it will hit and stop turning.
Re: converter bolts....best method tightening [Re: Cuda367] #1757910
02/18/15 07:02 PM
02/18/15 07:02 PM
Canada
onig Offline
onig  Offline
Canada
Start them all by hand first just enough for the converter to move a bit. Once all in, turn and tighten them all up. It helps to mark your converter and flex plate with a dab of paint to align it up and not waste time.
69 Dart
Re: converter bolts....best method tightening [Re: Cuda367] #1757911
02/18/15 07:04 PM
02/18/15 07:04 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I never tighten bolts on anything till I have them all started.
The 4 holes are asymmetrical so there's only one way all 4 holes will line up. It's possible to have 3 go in and the 4th won't. I put a paint mark on the flex plate and convertor before I install.
Make sure to use blue LockTite on the bolts, convertor bolts are famous for backing out.
Re: converter bolts....best method tightening [Re: B5 Bee] #1757912
02/19/15 12:09 AM
02/19/15 12:09 AM
Fla
birdboy Offline OP
birdboy  Offline OP
Fla
got it thanks
Re: converter bolts....best method tightening [Re: birdboy] #1757913
02/19/15 12:18 AM
02/19/15 12:18 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Where oh WHERE are the proper-torque-reading "police" ?
....as stated above ....get em all started - clean threads with fresh loctite ....then wrench em down with a box wrench and give that box a quick hit with a rubber
Re: converter bolts....best method tightening [Re: dOc !] #1757914
02/19/15 12:57 AM
02/19/15 12:57 AM
Cab_Burge Online work
Cab_Burge  Online Work
Lets see, the OP doesn't state which size converter bolts he using, 5/16 or 7/16 so it would be real hard to give him the proper torque specs., correct As far as the hammer, is that a small rubber or plastic mallet and a 4 inch long wrench or a 3 lb dead blow hammer with a 9 inch long combination box end wrench Is that enough to ignite the fires for tonight
Re: converter bolts....best method tightening [Re: Cab_Burge] #1757915
02/19/15 01:03 AM
02/19/15 01:03 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
FIRES ? ... ....
...and C B ... me thimks we are on the same page...
Re: converter bolts....best method tightening [Re: Cab_Burge] #1757916
02/19/15 02:12 PM
02/19/15 02:12 PM
gregsdart Offline
gregsdart  Offline
I wonder if they also torque the crank bolts the same way,,,,,,,,,,,,,,,
Re: converter bolts....best method tightening [Re: gregsdart] #1757917
02/19/15 02:18 PM
02/19/15 02:18 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
...jsta' little diff .... and I am sure that C B will agree .... I stagger the tightening of those said crank bolts ... because I sure don't want to distort the crank flange with that flex plate !!
Re: converter bolts....best method tightening [Re: dOc !] #1757918
02/19/15 03:05 PM
02/19/15 03:05 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I bought an 18 inch Matco ratchet wrench just for the 'verter bolts.After I had a few loosen up and hitting the block,thought I had a ROD KNOCK!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: converter bolts....best method tightening [Re: hemi-itis] #1757919
02/19/15 03:28 PM
02/19/15 03:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use my impact after I start them.. a short knock
and turn the start gear to the next one.. I go through
the starter area.. nice straight shot
Re: converter bolts....best method tightening [Re: MR_P_BODY] #1757920
02/19/15 03:35 PM
02/19/15 03:35 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Exactly what I do...36" extension. Done.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: converter bolts....best method tightening [Re: Adobedude] #1757921
02/19/15 04:25 PM
02/19/15 04:25 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
A thing I do is line up all the bolts outside of the car, making sure the converter and flex plate are in the right position. Then I just spray paint a line on both, makes the job really easy in the future.
Re: converter bolts....best method tightening [Re: SpareParts] #1757922
02/19/15 04:31 PM
02/19/15 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I do the same thing
Re: converter bolts....best method tightening [Re: hemi-itis] #1757923
02/19/15 04:36 PM
02/19/15 04:36 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I had the same thing happen to me. I was coming off of the freeway at 12 or 1 in the morning coming from a wedding years ago and it sounded like something was coming apart. The noise started like it was on a switch with no warning. I had oil pressure so; I drove it another mile or so to the house. The converter bolts were one of the first things I checked for some reason which I found odd becuase I'd never had the problem in the past. Put some locktite on them, tightened them up and never had another issue.
