Strange/Dana60 or Ford 9" in 70 cuda restomod? #1757871
02/18/15 05:46 PM
02/18/15 05:46 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
For the Mopar enthusiasts, please don't flame me. I'm really struggling with this one: I've been slowly working on my 70 Barracuda for 5 years now. I'm getting close to ordering a rearend and I need some input. This will have a 700ish HP initially (maybe 800 later) 6.1L based stroker w/ a supercharger, and 6 speed TR6060 manual trans. The rear suspension will be a panhard bar, 2 link, torque arm, and airbags. The wheels will be forged 3 piece and tires will be 345s (28.5" diameter)
Use will be mostly spirited street driving with occasional drag strip or auto cross duty.
Help a brother out. It mostly comes down to this: Do I want a sweet looking, tough D60 and save 100 pounds of unsprung weight or save $500 and use a 9" that will never look as good and would seem weird. What would you do? See my pro's and con's list below
Strange/Dana 60 pro's:
1.) 9.75" that is nearly indestructible (axle shafts rated for 850hp)
2.) Cheaper then Moser built 9" by about $500. Strange's rearends (35 spline axles, Ltd slip center section) are $1895.
3.) looks like it belongs in a classic Mopar
Strange/Dana 60 con's:
1.) 100lbs heavier then 9"
2.) limited gear choices (doesn't bother me because Strange offers 4.10's which should be perfect for my .50 6th gear)
Mosier/Ford 9" pro's
1.) 100 lbs lighter then Strange/Dana 60
2.) Adequate strength
3.) Lots of gear choices (don't care that much as I won't be swapping gears)
Mosier/Ford 9" con's
1.) $500 more expensive then Strange 60
2.) Pinion angle robs some power
3.) Adequate power but not quite as strong as the Strange/Dana 60
4.) Doesn't look like it belongs in a Mopar
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: 70B5Cuda] #1757872
02/18/15 06:54 PM
02/18/15 06:54 PM
AndyF Offline
AndyF  Offline
I think you might need to look at your packaging requirements. Can you put a torque arm and a panhard bar on a Dana 60? The rear cover might get in the way of the panhard bar. Where is the torque arm going to mount? Some of them bolt to the center section, some weld to the housing.
If you want a back brace on the rear end then you need to figure out where your shocks go and how the panhard bar fits into the equation.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: AndyF] #1757873
02/18/15 07:02 PM
02/18/15 07:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure a built 9" capable of handling what the S60 can is not all that much lighter.
http://www.hotrod.com/how-to/transmission-drivetrain/ccrp-0806-chevy-chevelle-rear-axle-swap/
Only true comparison I have seen between the S60, the 9" and the 12 bolt.
Read it and you will be surprised at the myths floating around regarding the 9".
Don't be the exception.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: Supercuda] #1757874
02/18/15 08:15 PM
02/18/15 08:15 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
Do yourself a favor and get the Big Ford ends. Like AndyF says, look at your packaging requirements. I would source a drivetrain shop near you and have them put BF ends and a nice third member in. Save the $$.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: go-fish] #1757875
02/18/15 08:55 PM
02/18/15 08:55 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Agreed on the big ford ends for either housing, many many more options for brakes (and cheaper too)
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: ntstlgl1970] #1757876
02/18/15 09:01 PM
02/18/15 09:01 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Spend some time sorting the gear ratio too with a .50 6th. your combination with 4.10's would be only turning 1700rpm in 6th at 70mph which might be too low depending on how your engine is setup. There is a free tremec app for phones that does the calculations for you.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: ntstlgl1970] #1757877
02/18/15 10:02 PM
02/18/15 10:02 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I have a 2010 Challenfer SRT8 with the same engine, Trans, tire diameter, and 3.91 gears. It does not like to drive 70-75. I have to drive faster then 80 to get rid of an annoying drone. I think the 4.10 will be perfect but I will run it through a calculator.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: Supercuda] #1757878
02/18/15 10:25 PM
02/18/15 10:25 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Thanks for the link-that was an excellent read! I had no idea the rearends were within 20 pounds of each other. I got the 100# number from a trusted vendor. Must not have been an apples to apples comparison or just bogus info.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: 70B5Cuda] #1757879
02/18/15 11:56 PM
02/18/15 11:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think you ought to go by the "without brakes" weight. In the article they used smaller drum brakes on the S60 and 12 bolt, with the 9" getting much bigger and heavier brakes, even so the weights are close either way.
I'm thinking, subject to packaging constraints, that the S60 wins based on cost. The other numbers are close enough, in either direction, for them to be a wash for all intents and purposes.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: Supercuda] #1757880
02/19/15 12:42 AM
02/19/15 12:42 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Put the explorer brake kit on, its the same as the Grand Cherokee but with better bearings. I went with the 60 because there is a lot of misinformation about back bracing and other issues, the 60 doesn't need back braced, the brace goes over the top. Lots of offroad guys out there welding up the 60's tubes to the housing and not one average person needs to do multiple gear swaps like claimed that they need a 9" for. It would be down to money for me. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: astjp2] #1757881
02/19/15 02:00 AM
02/19/15 02:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
9" gains you tunnel clearance because the pinion is so low.
Mopar to the bone!!!
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: Supercuda] #1757882
02/19/15 01:50 PM
02/19/15 01:50 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Cool. Looks like the S60 isn't as big a weight hog as we all thought and is somewhat more efficient than I would have guessed.
Of course, if you still want the quick gear change aspect of the 9", you could always go with the Mopar 8.75 and have even less total and rotating weight with pretty high torque level support.
Of course, as pointed out above, how many people really utilize the quick change aspect of the drop out third member? Probably even less than use the quick spring change aspect of coil overs for a suspension.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: TC@HP2] #1757883
02/19/15 05:34 PM
02/19/15 05:34 PM
washington
Bruce Offline
Bruce  Offline
washington
Call Dr Diff he sells both and ask him. He's a straight shooter.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: Bruce] #1757884
02/19/15 09:31 PM
02/19/15 09:31 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: 70B5Cuda] #1757885
02/20/15 05:10 AM
02/20/15 05:10 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I had an 09 with the same observations, 6th is a pretty useless gear
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: ntstlgl1970] #1757886
02/20/15 12:31 PM
02/20/15 12:31 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I chose my rear based on my brakes- fixed calipers do better with a full floater. I went 9" because it was easy and cheap to get a custom width full floater set-up.
Dana 60 would get my vote if you're going to pick a gear and stick with it (and run floater calipers).
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: Uhcoog1] #1757887
02/20/15 12:45 PM
02/20/15 12:45 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
One of our Mopar brothers in Haysville has a complete Dana 60 that he will let go for cheap that didn't sell at the swap last week.
Text me and I'll give you his number if you're interested.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: GY3] #1757888
03/02/15 09:56 PM
03/02/15 09:56 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Ordered a Strange 60 on Friday since their prices went up $400 starting today.
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: 70B5Cuda] #1757889
03/02/15 11:49 PM
03/02/15 11:49 PM
MI
chapdog105 Offline
chapdog105  Offline
MI
I bought a Strange S60 for my 69 RR vert from Summit with a coupon for 10% off. Buying it that way was the cheapest way to do it. I did plenty of research.
My logic was that the S60 was brand new, came bolt-in ready, and is bullet proof. I'm only running a slightly modified 440 that makes about 430 horses.
I opted for the 3.73 gear, powder coated with perches already mounted, and 11" drum brakes. I also upgraded the diff cover.
I have about 1100 miles on my full resto, and so far, so good.
Did I mention that it looks awesome?!?!?
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod? [Re: chapdog105] #1757890
03/03/15 12:43 AM
03/03/15 12:43 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Were those mufflers "clearanced" like that when you got them?
2 Demons...no, not my kids!
