Strange/Dana60 or Ford 9" in 70 cuda restomod?
#1757871
02/18/15 05:46 PM
02/18/15 05:46 PM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
For the Mopar enthusiasts, please don't flame me. I'm really struggling with this one: I've been slowly working on my 70 Barracuda for 5 years now. I'm getting close to ordering a rearend and I need some input. This will have a 700ish HP initially (maybe 800 later) 6.1L based stroker w/ a supercharger, and 6 speed TR6060 manual trans. The rear suspension will be a panhard bar, 2 link, torque arm, and airbags. The wheels will be forged 3 piece and tires will be 345s (28.5" diameter)
Use will be mostly spirited street driving with occasional drag strip or auto cross duty.
Help a brother out. It mostly comes down to this: Do I want a sweet looking, tough D60 and save 100 pounds of unsprung weight or save $500 and use a 9" that will never look as good and would seem weird. What would you do? See my pro's and con's list below
Strange/Dana 60 pro's: 1.) 9.75" that is nearly indestructible (axle shafts rated for 850hp) 2.) Cheaper then Moser built 9" by about $500. Strange's rearends (35 spline axles, Ltd slip center section) are $1895. 3.) looks like it belongs in a classic Mopar
Strange/Dana 60 con's: 1.) 100lbs heavier then 9" 2.) limited gear choices (doesn't bother me because Strange offers 4.10's which should be perfect for my .50 6th gear)
Mosier/Ford 9" pro's 1.) 100 lbs lighter then Strange/Dana 60 2.) Adequate strength 3.) Lots of gear choices (don't care that much as I won't be swapping gears)
Mosier/Ford 9" con's 1.) $500 more expensive then Strange 60 2.) Pinion angle robs some power 3.) Adequate power but not quite as strong as the Strange/Dana 60 4.) Doesn't look like it belongs in a Mopar
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: Strange/Dana60 or Ford 9" in 70 cuda restomod?
[Re: AndyF]
#1757873
02/18/15 07:02 PM
02/18/15 07:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pretty sure a built 9" capable of handling what the S60 can is not all that much lighter. http://www.hotrod.com/how-to/transmission-drivetrain/ccrp-0806-chevy-chevelle-rear-axle-swap/Only true comparison I have seen between the S60, the 9" and the 12 bolt. Read it and you will be surprised at the myths floating around regarding the 9".
[Re: 70B5Cuda]
#1757879
02/18/15 11:56 PM
02/18/15 11:56 PM
Supercuda
About to go away
About to go away
up yours
I think you ought to go by the "without brakes" weight. In the article they used smaller drum brakes on the S60 and 12 bolt, with the 9" getting much bigger and heavier brakes, even so the weights are close either way.
I'm thinking, subject to packaging constraints, that the S60 wins based on cost. The other numbers are close enough, in either direction, for them to be a wash for all intents and purposes.
[Re: Supercuda]
#1757880
02/19/15 12:42 AM
02/19/15 12:42 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Put the explorer brake kit on, its the same as the Grand Cherokee but with better bearings. I went with the 60 because there is a lot of misinformation about back bracing and other issues, the 60 doesn't need back braced, the brace goes over the top. Lots of offroad guys out there welding up the 60's tubes to the housing and not one average person needs to do multiple gear swaps like claimed that they need a 9" for. It would be down to money for me. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1757881
02/19/15 02:00 AM
02/19/15 02:00 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
9" gains you tunnel clearance because the pinion is so low.
Mopar to the bone!!!
[Re: Supercuda]
#1757882
02/19/15 01:50 PM
02/19/15 01:50 PM
Posts: 5,393 Pikes Peak Country
TC@HP2
Pikes Peak Country
Cool. Looks like the S60 isn't as big a weight hog as we all thought and is somewhat more efficient than I would have guessed.
Of course, if you still want the quick gear change aspect of the 9", you could always go with the Mopar 8.75 and have even less total and rotating weight with pretty high torque level support.
Of course, as pointed out above, how many people really utilize the quick change aspect of the drop out third member? Probably even less than use the quick spring change aspect of coil overs for a suspension.
[Re: Bruce]
#1757884
02/19/15 09:31 PM
02/19/15 09:31 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
Call Dr Diff he sells both and ask him. He's a straight shooter.
[Re: 70B5Cuda]
#1757885
02/20/15 05:10 AM
02/20/15 05:10 AM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Spend some time sorting the gear ratio too with a .50 6th. your combination with 4.10's would be only turning 1700rpm in 6th at 70mph which might be too low depending on how your engine is setup. There is a free tremec app for phones that does the calculations for you.
I have a 2010 Challenfer SRT8 with the same engine, Trans, tire diameter, and 3.91 gears. It does not like to drive 70-75. I have to drive faster then 80 to get rid of an annoying drone. I think the 4.10 will be perfect but I will run it through a calculator.
I had an 09 with the same observations, 6th is a pretty useless gear
[Re: ntstlgl1970]
#1757886
02/20/15 12:31 PM
02/20/15 12:31 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
I chose my rear based on my brakes- fixed calipers do better with a full floater. I went 9" because it was easy and cheap to get a custom width full floater set-up. Dana 60 would get my vote if you're going to pick a gear and stick with it (and run floater calipers).
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: GY3]
#1757888
03/02/15 09:56 PM
03/02/15 09:56 PM
70B5Cuda
Newton, KS
Ordered a Strange 60 on Friday since their prices went up $400 starting today.
[Re: 70B5Cuda]
#1757889
03/02/15 11:49 PM
03/02/15 11:49 PM
Posts: 143 MI
chapdog105
MI
I bought a Strange S60 for my 69 RR vert from Summit with a coupon for 10% off. Buying it that way was the cheapest way to do it. I did plenty of research. My logic was that the S60 was brand new, came bolt-in ready, and is bullet proof. I'm only running a slightly modified 440 that makes about 430 horses. I opted for the 3.73 gear, powder coated with perches already mounted, and 11" drum brakes. I also upgraded the diff cover. I have about 1100 miles on my full resto, and so far, so good. Did I mention that it looks awesome?!?!?
