Passenger door exterior mirror location. #1757859
02/18/15 05:46 PM
02/18/15 05:46 PM
Surrey, British Columbia
TseTse Runner Offline OP
My '69 RR (pillar coupe)had a non-stock exterior mirror mounted on the passenger door. I am currently working on the major bodywork section of the restoration and need to know if the current screw holes are in the right location. My intention is to replace the mirror that the car came with with a correct / stock mirror. What are the measurements for locating the mirror in the correct location?
Thanks.
TseTse Runner.
Re: Passenger door exterior mirror location. [Re: TseTse Runner] #1757860
02/18/15 08:11 PM
02/18/15 08:11 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I could be mistaken, but I'd be inclined to transfer measurements from the driver door.
Re: Passenger door exterior mirror location. [Re: 70Duster440] #1757861
02/18/15 08:32 PM
02/18/15 08:32 PM
Andrewh Online content
Andrewh  Online Content
if you mirror the driver side, you will find the mirror is useless in that position.
Cannot be seen by the driver.
however, I don't have any references to say where it should go, only that I recall it can't and wasn't placed like that.
Re: Passenger door exterior mirror location. [Re: Andrewh] #1757862
02/18/15 08:38 PM
02/18/15 08:38 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Well, there you go... Now you know where not to put it
Re: Passenger door exterior mirror location. [Re: 70Duster440] #1757863
02/18/15 09:19 PM
02/18/15 09:19 PM
Spokane Valley WA
dan6412 Offline
dan6412  Offline
Spokane Valley WA
Just my my 70 Charger has a factory mounted passenger mirror and it is truly useless for backing up and/or seeing in traffic.
If you still want to mount one I can messure it tonight for you.
Dan
Re: Passenger door exterior mirror location. [Re: dan6412] #1757864
02/19/15 03:29 AM
02/19/15 03:29 AM
Thanks for your input however it seems it is almost personal choice. Copy the location from the driver's door or locate it so it is useful. For my the mirror is there to be used not just a piece of scenery.
TseTse Runner
Re: Passenger door exterior mirror location. [Re: Andrewh] #1757865
02/19/15 03:42 AM
02/19/15 03:42 AM
Common sense would tell us not to locate it where it doesn't do any good. It has to be functional to have any effect safety wise. Thanks for your input.
TseTse Runner.
Re: Passenger door exterior mirror location. [Re: Andrewh] #1757866
02/19/15 09:41 AM
02/19/15 09:41 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
that's what I did with mine.USELESS!
Re: Passenger door exterior mirror location. [Re: bonefish] #1757867
02/19/15 10:16 AM
02/19/15 10:16 AM
Marion, Ohio USA
kab69440 Offline
kab69440  Offline
Marion, Ohio USA
I mirrored the driver's door location on my 69 Charger. The mirror works just fine and dandy there. I also have the seat at the farthest rearward lock. If you are an average sized person, you might want to mount it a few inches closer to the front of the door.
Just because you're paranoid, it doesn't mean they are not out to get you. WANT TO BUY- Looking for a CD by 'The Sub-Mersians' entitled "Raw Love Songs From my Garage To Your Bedroom". Also, any of the various surf-revival compilation albums this band has contributed to.
Re: Passenger door exterior mirror location. [Re: kab69440] #1757868
02/23/15 05:59 AM
02/23/15 05:59 AM
thanks for taking the time to respond.
I will follow your example.
Re: Passenger door exterior mirror location. [Re: TseTse Runner] #1757869
02/23/15 11:14 AM
02/23/15 11:14 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Hang tight for a bit, someone will post the engineering diagram bfore the day is out or at the very least accurate measurements of stock location. For some reason I am think it should have had a re-enforcemnt piece inside the door but only if it was a factory passenger side mirror car.
Careful, your character's showing!
Re: Passenger door exterior mirror location. [Re: mopar346] #1757870
02/23/15 05:15 PM
02/23/15 05:15 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That would be interesting as my experience is like the others. Mirror image the driver door and the passenger side mirror is useless.
