structure, chassis, rad core support question
#1757027
02/17/15 09:33 PM
02/17/15 09:33 PM
Posts: 591 Champion City
The Sphinx
Champion City
I'm building an early dart, the frame rails are already tied together and a 12 point cage is installed. I had to fab a new radiator core support with 1x1 square tube to move the radiator 3" forward and 1" down. In doing that I had to cut out the lower radiator support that ties the front of the frame rails together. My question is, do I need to replace it? The car is caged with bars going to the front rails plus the K frame is rigidly bolted into place. What's your thoughts?
Re: structure, chassis, rad core support question
[Re: Chad Bittle]
#1757031
02/18/15 12:31 AM
02/18/15 12:31 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I would, motor plate and then another cross member.
The motor plate is a structural member , but my poorly expressed sentiment is that the stresses you would be putting on it without a rigid cross member in front of it would be tremendous. When the idea is to stiffen up the chassis , removing key members is at a minimum counter productive.......and possibly dangerous. Years back , there was a fellow with a newly finished Henry J at BIR......beautiful car. He was expressing doubt about the rigidity of his radiator supports before his first lap in the car......a S/G ride. I saw the puff of liquid at about 3/4 track before he got in the water and put the car on it's lid. Moral of the story for me is if I have a doubt , I fix it.
[Re: Chad Bittle]
#1757032
02/18/15 12:40 AM
02/18/15 12:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yep.. add the brace to the front... even with a motor plate... it only makes the chassis more rigid which is what you want
