Felpro 8553 blue head gasket. Reuseable? #1756641
02/17/15 01:59 PM
02/17/15 01:59 PM
RapidRobert Offline OP
I'd always thought no but in a recent thread (reusing cometics) there was a post that you could with FP also. My situation is the eng was refreshed & then a head had to come back off before refiring & I wouldn't have a problem just purchasing another gasket but I did alot of cooling hole redrilling which then required smoothing the holes with a dremel which all in all ended up being a very significant amount of addit'l hours & if there is a reasonable chance of it being good I might chance it. Eng has not been fired. What do YOU guys think/suggest? Thank you for your time.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756642
02/17/15 02:57 PM
02/17/15 02:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've reused steel shim head gaskets on a 413 successfully. And I have had them fail too. Same with Felpro permatorques, though they are more forgiving than the shim type. It's hit or miss IMO. If you have a test stand you can fire and break in the engine and it holds up go for it. I, personally, hate trying to change a head gasket leaning over a fender, especially on a big block. At least that's my thinking but if I was to try it today I'd try it with a permatorque.
Don't be the exception.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: Supercuda] #1756643
02/17/15 03:22 PM
02/17/15 03:22 PM
Thanks bro , yeah my gut is sayin no but...
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756644
02/17/15 03:30 PM
02/17/15 03:30 PM
I don't recognize that part number but I have reused the standard cheapo 440/383 Fel Pro 8519 PT or is it 8517PT(CRS on the proper Pt #) as well as the 1009 with no problems Usually after breaking in the motor on the dyno and doing a inspection tear down before giving the motor to the customer, not a lot of street or strip use IHTHs
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756645
02/17/15 03:30 PM
02/17/15 03:30 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I did it with a 318 years ago with short hours on it. Can't remember the reason but the heads were peeled of the engine and slapped on another and I just sprayed the (permatorque) gaskets with gasket sealer and screwed it together. If was almost done as a goof, lets try this and see what happens.
Engine ended up being in THREE different vehicles before I lost sight of it. Came out of my Dart where it ran low 14's on street tires, sold to a buddy who installed it in his ramcharger and then ended up in a 77-78 Snow Commander plow truck at work.
The truck actually ran better with the 318 than it did with the 360-2 that was in it before.
When I left the job the truck was still plugging along if rotting apart at a good rate. Engine never gave a problem.
If that gaskets didn't stick to the head or deck I'd consider re-using them.
"I think its got a hemi"
Re: Felpro 8553 blue head gasket. Reuseable? [Re: gdonovan] #1756646
02/17/15 03:59 PM
02/17/15 03:59 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I reused a lot of gaskets back in the days of our no budget dirt track racing, but those 100,000 mile motors were short lived anyway. Don't think I'd do it with something I cared about. I'm getting old and too lazy to redo things like replacing gaskets because I was too cheap or lazy to use new ones the first time.
The last 20 or so years, every time I cut a corner, I got burned. Maybe its just payback from all the corners I got away cutting back when I was younger. Gene
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756647
02/17/15 06:10 PM
02/17/15 06:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
RR is that the marine gasket?If you havent fired Id reuse it.They are a pretty stout gasket.Just un bolt the same as you torque the head.Rocky
Chrysler Firepower
Re: Felpro 8553 blue head gasket. Reuseable? [Re: therocks] #1756648
02/17/15 08:15 PM
02/17/15 08:15 PM
I'll get over to my racing partners' shop & get a pic (& part #).
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756649
02/19/15 01:44 AM
02/19/15 01:44 AM
dogdays Offline
dogdays  Offline
Yup. the wisdom says if it hasn't been fired it's good to go a second time.
R.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: dogdays] #1756650
02/19/15 01:34 PM
02/19/15 01:34 PM
Alright Dog I will go with your advice & hope for the best. I definitely want to avoid all that Dremel work if I can. next time I think I (in the first place) will send a pattern to Cometic & let them cut one for me. On a seperate note the 3/16" alum spacers that Jerry Cjubatski (SDC concepts) in troy Michigan (A member here) cut for me were only $75 & were of premium workmanship (& the exacto knife cut pattern I sent him was a bit sloppy to say the least)
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756651
02/19/15 09:48 PM
02/19/15 09:48 PM
ky.
K
kenworth_goose Offline
K
ky.
As long as it hasn't been run I'd have no problem reusing it on any engine.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: kenworth_goose] #1756652
02/20/15 12:06 AM
02/20/15 12:06 AM
everytime I look at the compressed (areas) I start to worry but you guys are puttin me at ease
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756653
02/20/15 12:30 AM
02/20/15 12:30 AM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Probably be OK but do you want to take that chance for 25 bucks.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: Dartcuda] #1756654
02/20/15 01:25 AM
02/20/15 01:25 AM
Freeport IL USA
Freeport IL USA
Ah, look at the bright side, someone is going to get to tell you "I told you so!"
Re: Felpro 8553 blue head gasket. Reuseable? [Re: poorboy] #1756655
02/20/15 02:06 AM
02/20/15 02:06 AM
At least I was at ease for a little while, the price ain't nothing nor is the drilling but guess I'll have to bite the bullet & do the dremeling if I replace it. OH it just hit me that the problem was the HF one that if you breathe near it it'd stall. I will get a good one which oughta go 20X faster so If I do do it I'll be ready
Re: Felpro 8553 blue head gasket. Reuseable? [Re: RapidRobert] #1756656
02/20/15 09:51 AM
02/20/15 09:51 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
At a cost for new gaskets at $16 I'd rather be safe than sorry.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: TooMany62s] #1756657
02/20/15 10:50 AM
02/20/15 10:50 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I bought a 440 short block core off of craigslist, and at that time I had pulled the 440 out of my black 71 R/T. I wanted to be able to move the car around under it's own power. So I took that junkyard 440 short block and found all the bits and pieces to make a running engine. I sure wasn't going to buy a new gasket set. That engine is in the car, doesn't leak a drop of anything. ALL used Gaskets from different engines.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: scatpacktom] #1756658
02/20/15 12:21 PM
02/20/15 12:21 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Yep. Sometimes it works. The question is does it work every time?
Re: Felpro 8553 blue head gasket. Reuseable? [Re: TooMany62s] #1756659
02/20/15 04:06 PM
02/20/15 04:06 PM
dogdays Offline
dogdays  Offline
Don't be a wimp. NOTHING ever works every time.
R.
Re: Felpro 8553 blue head gasket. Reuseable? [Re: dogdays] #1756660
02/20/15 05:43 PM
02/20/15 05:43 PM
Don't be a wimp. NOTHING ever works every time. R.
That & I dont feel lucky
