Felpro 8553 blue head gasket. Reuseable?
#1756641
02/17/15 01:59 PM
02/17/15 01:59 PM
RapidRobert
I'd always thought no but in a recent thread (reusing cometics) there was a post that you could with FP also. My situation is the eng was refreshed & then a head had to come back off before refiring & I wouldn't have a problem just purchasing another gasket but I did alot of cooling hole redrilling which then required smoothing the holes with a dremel which all in all ended up being a very significant amount of addit'l hours & if there is a reasonable chance of it being good I might chance it. Eng has not been fired. What do YOU guys think/suggest? Thank you for your time.
Re: Felpro 8553 blue head gasket. Reuseable?
[Re: RapidRobert]
#1756642
02/17/15 02:57 PM
02/17/15 02:57 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I've reused steel shim head gaskets on a 413 successfully. And I have had them fail too. Same with Felpro permatorques, though they are more forgiving than the shim type. It's hit or miss IMO. If you have a test stand you can fire and break in the engine and it holds up go for it. I, personally, hate trying to change a head gasket leaning over a fender, especially on a big block. At least that's my thinking but if I was to try it today I'd try it with a permatorque.
[Re: Supercuda]
#1756643
02/17/15 03:22 PM
02/17/15 03:22 PM
RapidRobert
Thanks bro , yeah my gut is sayin no but...
[Re: RapidRobert]
#1756644
02/17/15 03:30 PM
02/17/15 03:30 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
I don't recognize that part number but I have reused the standard cheapo 440/383 Fel Pro 8519 PT or is it 8517PT(CRS on the proper Pt #) as well as the 1009 with no problems Usually after breaking in the motor on the dyno and doing a inspection tear down before giving the motor to the customer, not a lot of street or strip use IHTHs
[Re: RapidRobert]
#1756645
02/17/15 03:30 PM
02/17/15 03:30 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I did it with a 318 years ago with short hours on it. Can't remember the reason but the heads were peeled of the engine and slapped on another and I just sprayed the (permatorque) gaskets with gasket sealer and screwed it together. If was almost done as a goof, lets try this and see what happens.
Engine ended up being in THREE different vehicles before I lost sight of it. Came out of my Dart where it ran low 14's on street tires, sold to a buddy who installed it in his ramcharger and then ended up in a 77-78 Snow Commander plow truck at work.
The truck actually ran better with the 318 than it did with the 360-2 that was in it before.
When I left the job the truck was still plugging along if rotting apart at a good rate. Engine never gave a problem.
If that gaskets didn't stick to the head or deck I'd consider re-using them.
"I think its got a hemi"
[Re: RapidRobert]
#1756647
02/17/15 06:10 PM
02/17/15 06:10 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
RR is that the marine gasket?If you havent fired Id reuse it.They are a pretty stout gasket.Just un bolt the same as you torque the head.Rocky
Chrysler Firepower
[Re: therocks]
#1756648
02/17/15 08:15 PM
02/17/15 08:15 PM
RapidRobert
I'll get over to my racing partners' shop & get a pic (& part #).
[Re: dogdays]
#1756650
02/19/15 01:34 PM
02/19/15 01:34 PM
RapidRobert
Alright Dog I will go with your advice & hope for the best. I definitely want to avoid all that Dremel work if I can. next time I think I (in the first place) will send a pattern to Cometic & let them cut one for me. On a seperate note the 3/16" alum spacers that Jerry Cjubatski (SDC concepts) in troy Michigan (A member here) cut for me were only $75 & were of premium workmanship (& the exacto knife cut pattern I sent him was a bit sloppy to say the least)
[Re: poorboy]
#1756655
02/20/15 02:06 AM
02/20/15 02:06 AM
RapidRobert
At least I was at ease for a little while, the price ain't nothing nor is the drilling but guess I'll have to bite the bullet & do the dremeling if I replace it. OH it just hit me that the problem was the HF one that if you breathe near it it'd stall. I will get a good one which oughta go 20X faster so If I do do it I'll be ready
[Re: scatpacktom]
#1756658
02/20/15 12:21 PM
02/20/15 12:21 PM
Posts: 1,795 Greer, SC
TooMany62s
Greer, SC
I bought a 440 short block core off of craigslist, and at that time I had pulled the 440 out of my black 71 R/T. I wanted to be able to move the car around under it's own power. So I took that junkyard 440 short block and found all the bits and pieces to make a running engine. I sure wasn't going to buy a new gasket set. That engine is in the car, doesn't leak a drop of anything. ALL used Gaskets from different engines.
Yep. Sometimes it works. The question is does it work every time?
