Re: LOOKING FOR PICTURES MINI TUB DUSTERS
[Re: jas4210]
#1756064
02/16/15 10:29 PM
02/16/15 10:29 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Car in picture is mini tubbed to OEM frame rail,springs in frame,15x12 Centerline's with 7" backspace,31.0x16.50 Hoosier Pro Street radial,same size wheel with a 12.25x31.25 slick for the track.
[Re: a493demon]
#1756070
02/17/15 09:43 PM
02/17/15 09:43 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
On my Demon it had a stock width A-body 8 3/4 with the kit that moves the leaf springs in. I was running 28/10.5 W slick on a 10 in rim with stock wheel tubs. Also put the same setup under my 69 Valiant with stock wheel tubs. The rims were 4 7/8 back space.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
