Siamesed hemi block on the street #175584
12/26/08 08:01 PM
12/26/08 08:01 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
I was just wondering if anyone on here has had any cooling issues on the street.Im thinking of buying a 4.5" iron MP block. Probably 4.15 stroke with alum indy heads 10.5 compression.
Thanks Guys
CB
Re: Siamesed hemi block on the street [Re: crowbait] #175585
12/26/08 08:35 PM
12/26/08 08:35 PM
Richland MI
rvw Offline
rvw  Offline
Richland MI
I have one is a street car with a stock 26" radiator.526 cid 710 hp with mopar alun minum heads with no overheating issues. I even got stuck in a cruse in night last summer around 80 degrees out and went one city block in about 15 minutes with no problems never got over 195 degrees.
Re: Siamesed hemi block on the street [Re: rvw] #175586
12/26/08 09:33 PM
12/26/08 09:33 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've got one in my truck with iron hemi heads on it. The radiator is out of a '58 Newyorker. Been driving it for 2 years on the street, including in temps in the 90's, highway and lots of stop-in-go city traffic. No problems, go for it and have a little fun with the locals. Dave
Re: Siamesed hemi block on the street [Re: crowbait] #175587
12/27/08 12:36 PM
12/27/08 12:36 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I had a wedge version in my last car (630 HP 493). Used a Be Cool rad and clutch fan. It would get a little hot for my liking (190) in the heat while stuck in traffic, but as soon as you got moving it would drop right down to 175-180. This is more of a fan issue than a block issue. It should work fine.
Re: Siamesed hemi block on the street [Re: torkrules] #175588
12/28/08 10:26 AM
12/28/08 10:26 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Thanks guys. I will be in the market for one about march or april,when work picks up again.
Any opinion on where to buy?Im in western PA.
CB
Re: Siamesed hemi block on the street [Re: crowbait] #175589
12/28/08 12:36 PM
12/28/08 12:36 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I have a 528 Hemi with Stage V aluminum heads and I think that the fan/radiator set up is the key to keep these siamese blocks cool. I ran a fixed fan with a shroud and an aluminum radiator; no problem whatsover on the road. But once I got in traffic it climbed very quickly and I changed over to 2 electric fans and it helped the in town driving considerably.
QuickD100 and I bought our bare blocks from JEGS.
Re: Siamesed hemi block on the street [Re: crowbait] #175590
12/28/08 03:36 PM
12/28/08 03:36 PM
AndyF Online content
AndyF  Online Content
Check with your local Dodge dealer for pricing. You don't have to pay freight when you buy direct from the dealers so that can save you a bunch over a mailorder place.
Re: Siamesed hemi block on the street [Re: quickd100] #175591
12/28/08 06:58 PM
12/28/08 06:58 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I've got one in my truck with iron hemi heads on it. The radiator is out of a '58 Newyorker. Been driving it for 2 years on the street, including in temps in the 90's, highway and lots of stop-in-go city traffic. :
You are running E-85 Dave? It should make your engine run cooler...........of course you know that!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Siamesed hemi block on the street [Re: Rug_Trucker] #175592
12/28/08 07:28 PM
12/28/08 07:28 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
R/T; Acually I'm running it on 89.5 octane gasoline. I would have been running E-85 but I ordered pistons before E-85 was ever marketed. I'm at 10.6-1 and for E-85 I'd really prefer 13+-1. Just switching pistons isn't an option either as My rods are +.100 from stock with .990 pins. Dave
Re: Siamesed hemi block on the street [Re: quickd100] #175593
12/29/08 06:51 PM
12/29/08 06:51 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
How do you like the Stage V heads?
Is there more flow than the MP heads?
Re: Siamesed hemi block on the street [Re: crowbait] #175594
12/29/08 07:08 PM
12/29/08 07:08 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
I had Tim of FHO (FOR HEMIS ONLY) assemble and do a mild port job on them. At the time MP was having casting problems with them so I went with the Stage V and am very happy with them.
Re: Siamesed hemi block on the street [Re: Hemi_Ram] #175595
12/29/08 09:08 PM
12/29/08 09:08 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Did you get a finished bore block,or the 4.498 rough bore? .002 doesn't seem like a lot to finish up at 4.500. Or should I just get the finished block. But how round and straight are the bores? Yeah lots of questions here,thanks guys.
CB
Re: Siamesed hemi block on the street [Re: crowbait] #175596
12/29/08 09:37 PM
12/29/08 09:37 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
It's been almost 2 years since I purchased the block; at the time MOPAR was having problems with their foundry and 4.5" blocks that had enough thickness were few and far between. And most of the dealers were backordered. Now they are better quality and plentiful(so I am told) so you should be able to locate a dealer and might get a break on the price. Around here dealers are not performance orientated and won't give you a break on the MP products plus you have to pay the 6.75% tax on top of it. I had the block sonic checked and everything checked before we did any machine work. I did get the 4.498 rough bore and you have to figure the piston clearance on this so it is more than .002" you referenced.
Re: Siamesed hemi block on the street [Re: Hemi_Ram] #175597
12/29/08 10:52 PM
12/29/08 10:52 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Larry and I, (HemiRam) used the same machinist and had the same blocks 4.498 bore. Our machinist was the only guy between us and Minneapolis, Mn. with a 4.50 bore torque plate which was used to finish hone our blocks. He's also the same machinist that helped fix the lifter bore fiasco on the Moparts EM entree a few years ago. Dave
