Re: Mini Starter Lug Hits Block [Re: 1967dartgt] #1755514
02/17/15 01:16 AM
02/17/15 01:16 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Only problem on small blocks is a r3 block with 904 trans, need a starter from robbmc.
I am using an MSD starter on mine and it fits / works just fine.
Had I known about this one , I may have gotten off cheaper.
Re: Mini Starter Lug Hits Block [Re: tubtar] #1755515
02/17/15 02:02 AM
02/17/15 02:02 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
..... I can't believe I actually read this before I ever tried this. I have a decent 904, just no converter for the W8 mill..... but the thought had crossed my mind.
Re: Mini Starter Lug Hits Block [Re: 1967dartgt] #1755516
02/17/15 03:08 AM
02/17/15 03:08 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
no problem on any SB
Not true. 360 magnum blocks also have to be clearanced in the pan rail area to use a 904/998/999/A500 trans and a mini starter. Also, some of the mini-starters nose pieces need to be clearanced to use the solid B&M 360/904 flexplates.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
