Mini Starter Lug Hits Block #1755494
02/16/15 01:42 AM
02/16/15 01:42 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I got my mini starter from a V-8 Durango. The power lug is right up against the block. Starter bolts up great otherwise. Is there a fix for this or have I got the wrong starter? I could trim the tip of the bolt off about 3/16" but I'm concerned about arcing.
I’m listening.
Re: Mini Starter Lug Hits Block [Re: Big Bad Bee] #1755495
02/16/15 01:54 AM
02/16/15 01:54 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
mine did the same thing.i just ground the stud down till it didn't hit and all was good.
Re: Mini Starter Lug Hits Block [Re: bonefish] #1755496
02/16/15 02:03 AM
02/16/15 02:03 AM
Spokane Valley, WA
Spokane Valley, WA
I'll give it a try. I might coat the connector and bolt with plasti Dip if I can mount the cable before I get it in place. Tight squeeze between the headers.
I’m listening.
Re: Mini Starter Lug Hits Block [Re: Big Bad Bee] #1755497
02/16/15 02:25 AM
02/16/15 02:25 AM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
As said just cut the lug a little shorter.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Mini Starter Lug Hits Block [Re: Big Bad Bee] #1755498
02/16/15 12:43 PM
02/16/15 12:43 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Just cut down the lug. Also use a thinner nut, no washers and maybe sand/narrow the round end of the battery cable.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Mini Starter Lug Hits Block [Re: steve660] #1755499
02/16/15 01:35 PM
02/16/15 01:35 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
that's another thing I did used a narrower nut and replace the cable end with a copper one ,they are much tinner than the stock one you have.you can aklso just grind down a nut to make it tinner,just make sure you face the unground side down.I HEAR YA ABOUT THE HEADERS.
Re: Mini Starter Lug Hits Block [Re: bonefish] #1755500
02/16/15 02:09 PM
02/16/15 02:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
There is a different one that has the lug in a different spot a little further away from the block, run into that with the 440 in my old motorhome took it back to the parts house and swapped it for a different year if I remember correct and it worked just fine.
Re: Mini Starter Lug Hits Block [Re: dartman366] #1755501
02/16/15 02:20 PM
02/16/15 02:20 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Re: Mini Starter Lug Hits Block [Re: dartman366] #1755502
02/16/15 04:52 PM
02/16/15 04:52 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Yep mine is for a 92 pick up with a 360 cleared the block with no trimming of the stud !
Re: Mini Starter Lug Hits Block [Re: BuckeyeBrawler] #1755503
02/16/15 07:15 PM
02/16/15 07:15 PM
Spokane Valley, WA
Spokane Valley, WA
Great information and photos, guys. This is exactly what I need. This is why I love moparts!
I’m listening.
Re: Mini Starter Lug Hits Block [Re: Big Bad Bee] #1755504
02/16/15 08:11 PM
02/16/15 08:11 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
The last few Ive done I just hacked the lug down and had to extend the solenoid wire, and then move the routing on the large power wire.
Re: Mini Starter Lug Hits Block [Re: Moparnut426] #1755505
02/16/15 08:25 PM
02/16/15 08:25 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Mine was out of a 94 ram 2wd 1/2 ton 3.9 v6. I didnt have to cut it.
67' charger 499 RB 10.57 at 127
Re: Mini Starter Lug Hits Block [Re: dartman366] #1755506
02/16/15 08:34 PM
02/16/15 08:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think the issue here is that the OP is playing with
a BB and yes I had a clearance issue when I was building
mine... no problem on any SB
Re: Mini Starter Lug Hits Block [Re: MR_P_BODY] #1755507
02/16/15 08:37 PM
02/16/15 08:37 PM
Woodstock, IL
TurboMike Offline
TurboMike  Offline
Woodstock, IL
Re: Mini Starter Lug Hits Block [Re: TurboMike] #1755508
02/16/15 08:42 PM
02/16/15 08:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats all I did on the BB
Re: Mini Starter Lug Hits Block [Re: MR_P_BODY] #1755509
02/16/15 09:37 PM
02/16/15 09:37 PM
Woodstock, IL
TurboMike Offline
TurboMike  Offline
Woodstock, IL
Me too, but I didn't really use a sawzall
Re: Mini Starter Lug Hits Block [Re: MR_P_BODY] #1755510
02/16/15 09:59 PM
02/16/15 09:59 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Only problem on small blocks is a r3 block with 904 trans, need a starter from robbmc.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Mini Starter Lug Hits Block [Re: 1967dartgt] #1755511
02/16/15 10:15 PM
02/16/15 10:15 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Heres a picture of what cable looks like after I sanded/rounded end of cable. Also starter with shortened lug. The lug is offset but you can do same with any of them.
Re: Mini Starter Lug Hits Block [Re: steve660] #1755512
02/16/15 10:17 PM
02/16/15 10:17 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
2nd
Re: Mini Starter Lug Hits Block [Re: steve660] #1755513
02/16/15 10:17 PM
02/16/15 10:17 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
3rd
