Re: Bellhousing [Re: 300_dup5] #1754575
02/15/15 02:28 PM
02/15/15 02:28 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Terry here is a link to a 4-speed conversion I was involved with and there is some good information and pictures on how to setup and dial indicator.
https://board.moparts.org/ubbthreads/show...e=3#Post3272813
Gus
64 Plymouth Savoy
Dana 60
Re: Bellhousing [Re: fourgearsavoy] #1754576
02/15/15 03:35 PM
02/15/15 03:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Where are you in Ontario? If you're close, I have all the tools to check alignment.
The bearing retainer is a snug fit in the bell and often needs to be twisted and coaxed in. Also, the trans has to go in straight - best accomplished with some long bolts with the heads cut off installed in the top two holes in the bell.
Have you got the clutch disc in backwards? It installs one way only. If installed backwards the slines on the input shaft will bottom out before its all the way in. Just using an input shaft is no indicator that things are "right". It still may not be going in as far as it has to.
Re: Bellhousing [Re: 300_dup5] #1754577
02/15/15 06:40 PM
02/15/15 06:40 PM
ky.
K
kenworth_goose Offline
K
ky.
Yes, crank was drilled, brass sleeve is in, the input shaft that I'm using does not have the 4".3 retainer on the end, so it hard to tell how far off it is
The brass sleeve is flush with face of crank, shaft does slide into and to end of crank
So that's all good
Will try the trans again, without clutch, but by looking at it, retainer on input shaft will hit the one side again on bell
Will get it sorted out when I dial it in
First thing you need to do is take that junk brass bushing out and throw it in the garbage! Go buy a roller type bearing that is used in the later magnum applications and put that into the snout that a convertor would sit in if your had an auto trans. Put bellhousing on, put clutch and pressure plate onto the trans. shaft while not bolting the pressure plate to the flywheel until you have the trans. all the way into the bell. If pressure plate won't bolt up then you have a problem.
Re: Bellhousing [Re: kenworth_goose] #1754578
02/15/15 07:12 PM
02/15/15 07:12 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
So that's all good
So , how do you get the pressure plate and clutch disc into the bell housing after it's on the transmission and the bell housing is on the engine?..
Re: Bellhousing [Re: rowin4] #1754579
02/15/15 07:58 PM
02/15/15 07:58 PM
Rittman Ohio
Rittman Ohio
I'm pretty sure he is assuming the OP has a factory type bell that you can leave the plate loose on the flywheel and then tighten the plate once the tranny is bolted up
Gus
64 Plymouth Savoy
Dana 60
Re: Bellhousing [Re: fourgearsavoy] #1754580
02/15/15 08:33 PM
02/15/15 08:33 PM
rowin4 Offline
rowin4  Offline
I guess that maybe true about a stock open bottom bell housing as that [ your ] question was never answered about that. Also it was never asked or stated if the bearing retainer fits the bell housing hole . So, does the bearing retainer fit the hole? I have had some with a nick on the not allow it to slip in. If the bell housing is a open bottom, install the clutch / pressure plate with the bolts loose, then push in the transmission, then tighten the bolts.
Re: Bellhousing [Re: rowin4] #1754581
02/15/15 10:19 PM
02/15/15 10:19 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Bearing retainer on trans does fit bell hole, did that off the engine before,
Once I get this all dialled in, I'm sure all this will come together.
Yes if your close to me, by all means come out and give me a hand, I don't mind paying someone for there time on items I can't do,
Re: Bellhousing [Re: rowin4] #1754582
02/16/15 05:52 PM
02/16/15 05:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This is BS! These bushings have been used, problem free, for decades. The only reason they used a bearing was to save money on the crank drilling operation. Think about this ... the ONLY time the shaft spins in the bearing is when the clutch is in, otherwise, the shaft is turning with the crank. And what's more likely to fail, a solid bushing OR a mechanical bearing ?!?!?
That bushing is not your issue, leave it alone.
As for installing the assembly from the bottom ... REALLY ?!?!?
1) make sure there is not too much grease in the pilot hole. Grease will not compress and will limit how far the input can go in. Force it and it will start to push the bushing out!
2) make sure the disc is installed correctly - should have a stamp saying "flywheel side".
3) install disc and pressure plate using the input shaft to align the disc.
Go to Princess Auto and but the cheap dial indicator and magnetic base to dial in the bellhousing. I seriously doubt its out by 1/16". If it is you have a SERIOUS problem as there are no alignment dowels with that much offset.
Which raises the question ... are there dowels in the block now???
Unfortunately you're about 3 hours from me or I'd come and help.
Re: Bellhousing [Re: Stanton] #1754583
02/16/15 07:28 PM
02/16/15 07:28 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Terry,
There's been a lot of good info posted here...call me and we'll walk through it and see if anything jumps out...
...FAFO...
Re: Bellhousing [Re: skicker] #1754584
02/17/15 10:03 PM
02/17/15 10:03 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Well all is good, loosened bell bolts, Clutch etc, Slip trans in, no problem
Tightened bell, clutch etc, dialed in bell, was within specs,
put trans back in
Life is good
Thanks to all
Re: Bellhousing [Re: 300_dup5] #1754585
02/17/15 10:15 PM
02/17/15 10:15 PM
put trans back in
Life is good
Thanks to all
Congratulations That is good to hear I hope I have no scattersheild alignment problems on my newest 4 speed project I'll have to check it to make sure, no since in hoping Murphy loves messing with me
Re: Bellhousing [Re: Cab_Burge] #1754586
02/18/15 01:16 AM
02/18/15 01:16 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
So what was the problem?
Re: Bellhousing [Re: Cab_Burge] #1754587
02/18/15 01:19 AM
02/18/15 01:19 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Don't feel bad Cab...when he's not messing with you he's messing with me...
...FAFO...
Re: Bellhousing [Re: GTX MATT] #1754588
02/18/15 01:20 AM
02/18/15 01:20 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
See post 4 in this thread.
Don't be the exception.
Re: Bellhousing [Re: Supercuda] #1754589
02/18/15 01:28 AM
02/18/15 01:28 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re: Bellhousing [Re: Stanton] #1754590
02/18/15 01:42 AM
02/18/15 01:42 AM
rowin4 Offline
rowin4  Offline
I agree with you Stanton on the bushing, Dodge used that same bushing since 1928 through 1974
