Re: Bellhousing
[Re: 300_dup5]
#1754558
02/14/15 08:13 PM
02/14/15 08:13 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Wonder why you think the bellhousing is off.
More likely you do not have the clutch disc centered up.
I usually install the clutch, PP and bellhousing with the clutch fork and whatnot all set up, slide the trans in as far as it will go and if it will not completely go in have someone step on the clutch pedal and it'll release the pressure plate allowing the disc to center up.
Re: Bellhousing
[Re: 300_dup5]
#1754559
02/14/15 08:33 PM
02/14/15 08:33 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I have to get a dial indicator, just a measurement with measure Had new clutch in, new bell on Tried to fit 833 in, no way. Stopped about 1/4" from going in It did start into new pilot bushing Took it all apart ( after using one of those plastic tools Got a steel input shaft, and this is where I'm at
The final 1/4 inch of travel is usually the front bearing retainer lip not entering into the bellhousing correctly Let us know what you find out, maybe you have the large bearing retainer and the small hole bellhousing Good luck BTW, one of the easest fixes on that deal is to have the bearing retainer O.D. turn down to the proper size, unless you have a 18 spline NP 833 instead of the 23 spline tranny
Re: Bellhousing
[Re: 300_dup5]
#1754560
02/14/15 08:39 PM
02/14/15 08:39 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
So the this particular engine always has a 4-speed bolted to it right? Is this bellhousing the only new part in the equation? Does the input bearing retainer fit the bellhousing? I have a special tool that another member here made from my drawings and it works much better than a magnetic base on the crank. I have a pic of it on my laptop I can post later Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Bellhousing
[Re: fourgearsavoy]
#1754561
02/14/15 09:43 PM
02/14/15 09:43 PM
Posts: 219 Ontario Canada
300_dup5
Ontario Canada
New bell, new clutch new everything, Engine was not 4 speed before I had everything bolted up, went to slide trans in and input shaft retainer on new trans actually was hitting side of bell hole, not allowing it to go any further. Took bell off, clutch out, got a steel input shaft off another 833 , slide in perfect into crank and pilot sleeve Put bell back on ( no clutch) and tried again , goes in fine ( the steel 833 input shaft does not have retainer on end) Just doing some rough measurments from shaft to bell on both sides , shows its off about 1/16". Whatever that maybe in thousandths If I hold shaft over to one side it's much better, but you can feel the resistance when turned Got to get a dial indicator I slide my finger down left side, down right side a little resistance ??? Maybe a good shot on right side of pinion shaft would straighten it ( just kidding
Re: Bellhousing
[Re: 300_dup5]
#1754563
02/14/15 10:01 PM
02/14/15 10:01 PM
fourgearsavoy
Rittman Ohio
So the transmission bolts right in without the clutch Well you should check it anyway so if it's off that far it won't be easy to fix. Here's a pic of my alignment tool. What kind of bellhousing is it? Gus
Re: Bellhousing
[Re: fourgearsavoy]
#1754564
02/14/15 10:09 PM
02/14/15 10:09 PM
300_dup5
Ontario Canada
Trans doesn't bolt up, spare trans spline ( without retainer on it) does Got it from Mancini. Aluminum, No clutch in it at this time
Re: Bellhousing
[Re: 300_dup5]
#1754565
02/14/15 10:16 PM
02/14/15 10:16 PM
fourgearsavoy
Rittman Ohio
If it won't even bolt up without the clutch then something is off further than I've ever seen before. So the tranny bolts up to the bell when it's not attached to the engine right? And the crank is drilled deep enough to accept the input pilot. Gus
Re: Bellhousing
[Re: 300_dup5]
#1754572
02/15/15 01:35 AM
02/15/15 01:35 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
You say that the engine was not a 4 speed before, was the crank drilled for a stick input shaft? You say it slides into the pilot sleeve , is that a standard replacement bushing and installed all the way in? What do you mean { the steel 833 does not have a retainer on the end] ? There are offset dowels available to dial in the bell housing if you need to. Robbmc performance sells what you need.
Re: Bellhousing
[Re: rowin4]
#1754573
02/15/15 02:13 AM
02/15/15 02:13 AM
rowin4
With the bell housing back on with no pressure plate installed, I use a magnetic based dial indicator to zero in the bell housing. The magnetic base is stuck on between the [ clean ] flywheel bolts , the indicator is setup to run on the large surface hole of the bell housing that the transmission bearing retainer fits in. I mark the harmonic balancer every 45 degrees . Turn the crankshaft from the front crank bolt. Take a reading , write it down at each 45 degrees till you complete a full rotation. This will tell you whether your bell housing is good to go or not. I think .010 total indicator run out is acceptable. Google that for proper info. If it is out contact Robbmc for the proper Mopar offset dowels.
