1984 Dodge D100 questions #1754229
02/14/15 02:48 AM
02/14/15 02:48 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Hello everyone! Have some questions for. I have a 1984 Dodge D100 with a 318 and a 833 overdrive tranny. Its a short bed. I am wanting to make more power with the 318. Its bone stock. Except for the ignition has been converted over to a stock electronic ignition. My plan is to put magnum exhaust manifolds on it off of a 5.2 and then have a dual exhaust installed. Sunday I am going to look at a Edelbrock LD4b intake. The only thing is the guy said that the intake has been gasket matched and now has bigger ports than a 318. Said it was on a 340. Will that matter? I know that this intake was originally for a 318 correct? I may add a cam down the road. I may add a 360 way down the road, a 89 Dakota is my main project right now. Just wanting to wake the 318 up! Does this sound like a good plan? Right now the truck has a 8.25 rear with 2.94 gears non suregrip. The guy with the intake says he has a 9.25 out of a 89 Dodge truck that has a suregrip and 3.55 gears. Said it would be a easy install. I have never done that before. Only familiar with 8 3/4 rears. I also found a suregrip unit- I think it is, for the 8.25 rear. It is a 27 spline. I will try to post a couple of pictures and let me know if it is. If it is, I could just buy the gears that I want and have it all installed correct?
Re: 1984 Dodge D100 questions [Re: 360D100] #1754230
02/14/15 02:49 AM
02/14/15 02:49 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
Here is another pic
Re: 1984 Dodge D100 questions [Re: 360D100] #1754231
02/14/15 07:01 AM
02/14/15 07:01 AM
SW Missouri
moparmandjh Offline
moparmandjh  Offline
SW Missouri
I think an Air Gap intake would serve you much better.
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
Re: 1984 Dodge D100 questions [Re: moparmandjh] #1754232
02/14/15 07:29 AM
02/14/15 07:29 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
The Air Gap would be better than the LD4B?
Re: 1984 Dodge D100 questions [Re: 360D100] #1754233
02/14/15 08:11 AM
02/14/15 08:11 AM
USA
360D100 Offline OP
360D100  Offline OP
USA
If that is a suregrip for a 8.25 is that the right one where I could use lower gears like say a 3.55 etc.?
Re: 1984 Dodge D100 questions [Re: 360D100] #1754234
02/14/15 02:40 PM
02/14/15 02:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Leave the 318 alone for now. I would swap in the 9.25 rear. If it was working, it would be an easy swap (and likely cheaper) than buying a 8.25, plus it will hold more power than the 8.25. The gears will help out your 318 off the the line.
Re: 1984 Dodge D100 questions [Re: DaytonaTurbo] #1754235
02/14/15 03:50 PM
02/14/15 03:50 PM
scratchnfotraction Offline
rpm air-gap is a little to much intake on a stock 318
the LD4B is the best intake for a 318. if has been ported to the 340 size opening. just use a fiber 340/360 gasket felpro 1213
that intake wakes a stock 318 up real nice. I used a 660 eddy carb on mine.
it also worked great on the 360 headed 318 police engine I have.
watch the truck axle/carrier/c-clip/wheel bolt pattern change in 85 when sorcing parts to rebuild the 8 1/4 9 1/4 truck axles.
Re: 1984 Dodge D100 questions [Re: 360D100] #1754236
02/14/15 03:54 PM
02/14/15 03:54 PM
watch the magnum manifolds IIRC the dump right on the starter and do not fit the d series truck chassis due to shifter linkage/starter
use a set of long tube hedmans
79080 for 2x truck and 79170 for a 4x4 or 2x truck chassis
79250 for BB truck chassis
Re: 1984 Dodge D100 questions [Re: 360D100] #1754237
02/14/15 07:22 PM
02/14/15 07:22 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
like scratch said, the ld4b is great for the 318. get a good carb, and i'd just get some headers and run the duals. if the 9.25 was in a truck, it should bolt right in. those 3:55's will wake up the truck nicely. if you keep your rear, look at a 3:91 for your 8.25 and a suregrip. trucks are light enough in the rear, to not worry about hard hook-ups, and breaking stuff. (unless you load the bed down, and run some wide slicks.) if you're really feeling adventurous, a 1968 340 stick cam will make the 318 wail, along with the other things from above.
Re: 1984 Dodge D100 questions [Re: Golden-Arm] #1754238
02/18/15 08:29 PM
02/18/15 08:29 PM
USA
360D100 Offline OP
360D100  Offline OP
USA
Will I found out that the suregrip unit that I posted would not work. What would be the easiest and cheapest way to get a suregrip in my truck? I cant find anything local as far as complete rears. Although I did find a rear out of a 95 Dakota 8.25 rear with a 3.55 suregrip. Would that work, the insides? It has 3.55 gears. I would like to find a complete rear that I could just bolt in. But not having any luck. If I get a suregrip and some gears I will have to have a shop swap that and set it up. Any help would be greatly appreciated.
Re: 1984 Dodge D100 questions [Re: 360D100] #1754239
02/19/15 12:29 AM
02/19/15 12:29 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A 95 (91 and newer) Dakota rear end will have 6 bolt wheel flanges. It will probably bolt into your truck, but you will need the rear 6 bolt wheels.
Unless you stick with the same era (82-93 full size truck) Dodge truck rear end, your wheel bolt pattern will likely be different then what you have now, be sure to get wheels to match the bolt pattern for the rear axle you end up with. Gene
Re: 1984 Dodge D100 questions [Re: 360D100] #1754240
02/19/15 09:28 AM
02/19/15 09:28 AM
you can use a rear axle from a mid 70s c-body car. it is correct width for the trucks but would need spring perch relocated.
some of the Daks share the same 43" perch centers and early DAks have the 5 on 4.5 wbp BUT.. axles are a little narrower. (DAKS use a B-body 8 3/4 and mini tubs)
I have a A-body 8 3/4 bolted in my 88 truck tucking 12" rims 29x15x15 M/Ts
and a B-body axle should only be a little narrower than stock with truck axle.
truck and c-body 8 3/4 housing is 59" flange to flange.
94 jeep cherrokee shares the same 43" perch centers and will bolt in the truck but will need tubb work with a 10" - 12" rim at least.
just depends on what you can find and willing to do.
Re: 1984 Dodge D100 questions [Re: scratchnfotraction] #1754241
02/19/15 11:00 AM
02/19/15 11:00 AM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
I have a b-body axle housing and axles that will eventually get swapped under my 73 so I can run some 15x10 slots (3.5" back spacing). If my measurements are right it will narrow it just enough to get them to tuck up in the fender, and i'm hoping the center sections will swap right over.
Re: 1984 Dodge D100 questions [Re: lunacy] #1754242
02/19/15 03:06 PM
02/19/15 03:06 PM
dogdays Offline
dogdays  Offline
The 9.25 with the 3.55s and Suregrip is the easiest. By this I mean unbolt your current rear axle, bolt in the new axle. The driveshaft length will be the same, the 8.25 and 9.25 were the same distance between axle centerline and U-joint.
There's no reason to even smell gear oil on this swap. It's just remove and replace. Well, you will have to bleed the rear brakes, but nothing more complicated than that.
As for the intake, you have many choices. The LD4b is good, the LD340 or RPM Air Gap would be good, the Performer would be good, even the stock cast iron spreadbore intake that was used on 360s is good, if heavy.
Get a carb that matches the flange on the intake. I have had middling results with square to spread adapters.
Don't worry about the port mismatch, at this power level it has no effect. Just use a gasket that will seal whichever larger holes you have. I guess that'd be a 360 gasket.
Even with the wimpy 318 cam the 4 barrel and dual exhaust will help a lot, even better with 3.55s.
Keep it simple and you'll have success.
R.
