Page 1 of 3 1 2 3
Starting problems 71 Challenger #1753894
02/13/15 07:02 PM
02/13/15 07:02 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Hi
I'm new here and having a few problems with my 71 Challenger. I have spent the last 3 years completing a restoration that was started by the previous owner.
I am almost done and just finishing off making a custom dash board will new gauges. Most of the time I've owned the car its always started and run, sometimes taking a while to start due to it standing but always started eventually.
Recently though, all I am getting is a clicking noise like the starter solenoid is sticking? Try as I may, it just ckicks. I've tried the old technique of giving the starter a bash with a lump of wood but this isn't working.
I've also noticed the ballast resistor is get very very hot, not sure if this is more than usual as I know they get hot but to the point where it smells like burning and smokes (this may be the WD40 I sprayed on it when cleaning and re-fitting)
Anyway, anyone got any ideas on the starting problems, I suspect starter and/or solenoid but wanted to check I wasn't missing anything before ordering a new one.
Battery is fine and kept on a maintenance charger, so always fully charged.
Thanks.
Re: Starting problems 71 Challenger [Re: Wiggy] #1753895
02/13/15 07:25 PM
02/13/15 07:25 PM
Ohio
ChallengerTA Offline
Ohio
Could be connection at Battery. Remove and clean both terminals. Check connections at starter motor. Remove and clean all terminals on starter motor.
Jason
1970 Challenger T/A
Re: Starting problems 71 Challenger [Re: ChallengerTA] #1753896
02/13/15 07:31 PM
02/13/15 07:31 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Battery connections are OK, I've had it off recently and its all clean. I will check the starter connections as well, maybe take them off and clean just to be sure
Re: Starting problems 71 Challenger [Re: Wiggy] #1753897
02/13/15 07:43 PM
02/13/15 07:43 PM
Hi I'm new here and having a few problems with my 71 Challenger.
Welcome aboard! A clicking solenoid ain't sticking but instead does not have enough voltage at the solenoid once the solenoid rod moves far enough to engage the starter (not enough left for the "holdin" winding to keep it engaged. So it releases & with the starter disengaged there is now enough juice for the "pull in" solenoid to pull it in again & it repeats this cycle in rapid fashion & that is the clicking you are experiencing. You're sure the batt is good? Clean ALL LARGE cables/terminals: batt to starter relay/starter relay to starter/batt neg to sheetmetal/sheetmetal to eng block/starter to block including both sides of the flat plate (if used)
Re: Starting problems 71 Challenger [Re: RapidRobert] #1753898
02/13/15 11:32 PM
02/13/15 11:32 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Hi, thanks
I assume the battery is OK, it was fine last time it was started and turned the engine over no probs until it fired. As mentioned I don't start that often as I am in the middle of finishing it off but like to start it once in a while and get it up to temp just to make sure everything stays free.
When not running the battery is on a maintenance charger to keep it topped up and stop the alarm draining the battery.
When I turn the key to start it clicks like the solenoid has popped, the when I release the key it clicks back. It does sound like a flat battery but even if the battery wasn't at its best, I'd still expect it to turn the engine, even slowly??
I'll check all connections but from a quick check early all look good. I'll take them apart and spray on some WD40 or something to make sure all contacts are good.
Thanks again
Re: Starting problems 71 Challenger [Re: Wiggy] #1753899
02/13/15 11:34 PM
02/13/15 11:34 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Starter could be locked/entangled with flywheel. Remote chance. If standard shift put in top gear, give car a push with clutch out and see if engine turns over. If locked starter this will normally free it up. Pushing car backward is recommended.
Could engine be hydro locked. Unlikely but just throwing stuff against the wall.
Have you tried jumping car at point where battery cable and ignition switch wiring come together(relay)next to battery,,,,meaning bypass ignition switch to turn over.
Are battery cables clean and tight at each end?
If this all fails would suspect selonoid or starter itself.
Re: Starting problems 71 Challenger [Re: Sxrxrnr] #1753900
02/13/15 11:47 PM
02/13/15 11:47 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Thanks for the comments/ideas.
I thought that too about the engine and sadly don't have a socket big enough to fit the crank pulley bolt and it's an auto so can't put in gear to move it that way. I can move the pulley a very small amount by hand holding onto the pulley itself, which suggest the engine is OK. As mentioned it was running a couple of months ago no probs and the engine oil is clear and relatively new.
I might try the bypass idea you mentioned to take the starter relay out of the mix but the fact that it's clicking suggests the relay is doing what it should.
I might take the one of the batteries out of my truck as well and try that on there, I know they are good batteries on that
Re: Starting problems 71 Challenger [Re: Wiggy] #1753901
02/14/15 12:16 AM
02/14/15 12:16 AM
You might take off the 2 cables off of the starter & clean the 2 (large/small) terminals with a wire brush then clamp a red jumper cable on both of em and the black jumper cable end to the nearby starter ear then connect the other ends of the jumper cables to your truck battery setting on the ground by the Dr front wheel & see if it cranks. this'd keep the "connection" sparks from messing up the starter threaded studs which it would if you made your last connection at the starter. This'll take the batt/starter/eng lockup out of the way.
Re: Starting problems 71 Challenger [Re: RapidRobert] #1753902
02/14/15 12:36 AM
02/14/15 12:36 AM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Good idea, I was considering removing the starter altogether to try this but makes sense to leave in situ, saves the starter jumping all over my bench as well
Re: Starting problems 71 Challenger [Re: Wiggy] #1753903
02/14/15 01:33 AM
02/14/15 01:33 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Almost sounds like a bad battery that shows it has a good charge...If not I think I would pull all of the plugs if it was me and see if it will turn over freely.
You never know a float may have stuck and it could be hydraulic locked...
...FAFO...
Re: Starting problems 71 Challenger [Re: skicker] #1753904
02/14/15 02:46 AM
02/14/15 02:46 AM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
First step would be a voltmeter on battery. 12.5 volts as it sits. Crank car. If it stays 12V or so, the starter isnt kicking in and dropping it down. Check for 12V on small terminal of starter. If 12V there and 12V on big terminal, starter is issue. If not 12V on small wire, relay or wiring is the issue. If it drops to like 10V or less, starter is getting voltage on both terminals, drawing power and trying to go. Still might be starter, or battery may just be weak.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: Starting problems 71 Challenger [Re: moparjimbo] #1753905
02/14/15 02:20 PM
02/14/15 02:20 PM
Tacoma, Washington USA
Adam71Charger Offline
Ive had a battery show 12v and still not deliver enough current to starter due to corroded wire. corroded wires and bad grounds are typically the cause of electrical problems on older cars. Sometimes the battery cable looks fine from the outside but cut it open and its corroded and breaking apart.I would try what robert said and deliver full voltage to the starter with good cables as a start
Re: Starting problems 71 Challenger [Re: Adam71Charger] #1753906
02/14/15 03:02 PM
02/14/15 03:02 PM
I would not put WD40 on your cleaned cable terminals. Holler with any news
Re: Starting problems 71 Challenger [Re: RapidRobert] #1753907
02/14/15 09:10 PM
02/14/15 09:10 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Thanks heaps for the help guys, going to get stuck into it tomorrow when I have a free day. I'll let you know what I find
Re: Starting problems 71 Challenger [Re: moparjimbo] #1753908
02/14/15 09:53 PM
02/14/15 09:53 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Just did the first bit of this, battery off the charger holds just over 13v, then drops to 12.5 when I crank the first time. This then creeps back up on its own to around 12.6-12.7v, when I crank it drops to about 12.5, which suggests the starter isn't drawing power from it enough to crank it over?
Re: Starting problems 71 Challenger [Re: Wiggy] #1753909
02/14/15 11:58 PM
02/14/15 11:58 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Went thru the same kind of issue. The very last thing that I checked was the end of the neg battery cable that connect's to the intake or block. Mine looked ok but I turned the end so that the little teeth ground into the intake and it cranked like never before and this was after restoring the car.
Re: Starting problems 71 Challenger [Re: 72 RR DUDE] #1753910
02/15/15 12:23 AM
02/15/15 12:23 AM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
OK, managed to get out and do a few more tests.
Battery seems fine as mentioned, so lets assume for now this is OK, holds charge well and recovers quickly once I've tried to crank the engine, which suggests its ok.
Checked power to terminals on the starter
Small terminal 0 volts when nothing is happening and around 11.5v when I turn the ignition key, so relay must be working OK.
Large terminal reads the same as the battery, about 12.5v and then drops slightly when I turn the key, down to say 12.2(ish)
The clicking is deffo the starter jumping out, I can see this from under the car with the dust plate off the bottom of the bell housing. I turned the engine over manually using the flywheel, so its not locked.
What I did notice though is the starter pops out (clicks) but doesn't engage the flywheel teeth, it pops out and then goes straight back in, which would suggest the solenoid is OK as well otherwise it wouldn't jump out at all, right?
I'll check connections etc now as well but these were all fine last time I started it and its not moved since, so can't imagine why they would be bad all of a sudden?
Any ideas?
Re: Starting problems 71 Challenger [Re: 72 RR DUDE] #1753911
02/15/15 12:58 AM
02/15/15 12:58 AM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Just been out and cleaned the end of the terminal where it joins to the engine block, all lovely bare metal now on all joining faces and still it just clicks Looking more and more likely I'll need to take out the starter I think, which is a pig because of the header being in the way...
Re: Starting problems 71 Challenger [Re: Wiggy] #1753912
02/15/15 06:54 AM
02/15/15 06:54 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
It has to be either a bad battery, bad electrical connection or simply a bad starter/solenoid! Try another known good battery and remove and check all electrical connections. The fact that is has fired and ran just recently points to battery/connection issue! Good luck and I am sure you will figure it out.
Re: Starting problems 71 Challenger [Re: SCATPK] #1753913
02/15/15 06:23 PM
02/15/15 06:23 PM
New Zealand
W
Wiggy Offline OP
Wiggy  Offline OP
W
New Zealand
Yeah its a funny one for sure. I wonder if my amps being connected to the battery are having an affect? I also have a capacitor running to one of the amps, which may be messing with the starting current? I'll try removing them from the equation first, then try my truck battery and hope it has enough juice.
The joys of classic car restoration
Page 1 of 3 1 2 3
