Internal balanced Marine LA 360? #1753764
02/13/15 05:05 PM
02/13/15 05:05 PM
USA
ramairthree Offline OP
USA
I have a 74 RR running on a non original 318.
Original small block to the car is long gone and this is a junk yard late 70s 318 running on most cylinders and some compression. It is not worth a rebuild.
I was looking at a low cost engine options.
An LA 360 or 408 stroker.
A buddy said the best buy he has seen in to get a standard rotation marine 360.
That should leave me able to hook up to the original 904 but would need to change the balance.
Nope he said, they make internally balanced 360s that bolt right in. Just throw all my same parts onto it.
Has anyone done this. It would be great to spend just two K on an engine.
Re: Internal balanced Marine LA 360? [Re: ramairthree] #1753765
02/13/15 05:22 PM
02/13/15 05:22 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've never heard of an internally balanced 360 from the factory...then again I've never messed with a marine engine either.
If it wasn't in fact internally balanced the worst you would be looking at is a new convertor...maybe a flex plate...
...FAFO...
Re: Internal balanced Marine LA 360? [Re: skicker] #1753766
02/13/15 06:00 PM
02/13/15 06:00 PM
USA
USA
Re: Internal balanced Marine LA 360? [Re: ramairthree] #1753767
02/13/15 07:24 PM
02/13/15 07:24 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Looks like you have to re-use all of your accessories.
Without all those extra parts it sounds a little high to me. I'd think you could freshen what you have for less than that.
Marine cam...wonder what the specs on that would be...
...FAFO...
Re: Internal balanced Marine LA 360? [Re: skicker] #1753768
02/14/15 06:42 PM
02/14/15 06:42 PM
USA
USA
High RPM HP and crappy low end torque.
Re: Internal balanced Marine LA 360? [Re: ramairthree] #1753769
02/14/15 11:18 PM
02/14/15 11:18 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Boat motors are pretty much the opposite unless you are talking race hydroplane. Civilian stuff is mostly all done by 4800-5000ish and cruise 2800-3200.
Kevin
Re: Internal balanced Marine LA 360? [Re: ramairthree] #1753770
02/15/15 12:22 AM
02/15/15 12:22 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
I know absolute zero about boat motors, but a friend bought the twin 413s out of a burnt boat, (never used them, one counter rotated tho) and it seems to me that they had a different rear flange, maybe like an industrial engine? I haven't seen them in years, but he probably still has them somewhere, never parts with anything ...
I suppose it is possible that it was just an old boat, and they were pre 62 style cranks.
It may be that newer boat engines use the standard flange though.
Just something for you to be sure of before buying.
It takes gasoline to interest me.
