coronet 440 tail lights. Is there a right and left? #175363
12/26/08 02:06 PM
12/26/08 02:06 PM
Andrewh Offline OP
Andrewh  Offline OP
Are they the same for both sides, or is there a right and left?
They look the same to me, but want to be sure.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175364
12/26/08 02:35 PM
12/26/08 02:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I would think they are different. If you look close there should be a L or and R on them by the part number.
Re: coronet 440 tail lights. Is there a right and left? [Re: Mr.Yuck] #175365
12/26/08 02:52 PM
12/26/08 02:52 PM
Andrewh Offline OP
Andrewh  Offline OP
don't see a part number on them. Is it under the housing?
Didn't want to take them both apart till I knew for sure. The housing seems a bit rusted and am afraid to break anything.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175366
12/26/08 02:55 PM
12/26/08 02:55 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
Should be a right and left. Need a set?
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: coronet 440 tail lights. Is there a right and left? [Re: gtsuperbee] #175367
12/26/08 03:05 PM
12/26/08 03:05 PM
Andrewh Offline OP
Andrewh  Offline OP
looking at a single. Didn't know if it mattered.
Thanks.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175368
12/29/08 05:19 PM
12/29/08 05:19 PM
Andrewh Offline OP
Andrewh  Offline OP
Okay, I took them apart, and it seems like everything but the housing is interchangable.
The housings are marked right and left.
The piece that holds the reverse lenses in are not marked, but they have different part numbers.
The back up lenses are identical.
The brake lenses fit in both housings. but are totally different part numbers. Not just odd and even for the housings and backup lens housings.
But they are both odd numbered part numbers. One ends in 911, the other ends in 907.
One fits better in both housings than the other.
Was this just a different run of parts? Or did someone stuff both left lenses in my car? It isn't marked left or right like the other stuff.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175369
12/29/08 06:35 PM
12/29/08 06:35 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
What year coronet?
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175370
12/29/08 07:12 PM
12/29/08 07:12 PM
GMP440 Offline
GMP440  Offline
The inner housings are labeled rit and left. The chrome outer bezels are strictly right and left.
Re: coronet 440 tail lights. Is there a right and left? [Re: GMP440] #175371
12/29/08 07:18 PM
12/29/08 07:18 PM
Andrewh Offline OP
Andrewh  Offline OP
sorry. 65 coronet.
The housings seem to be. My question really was, are the lenses.
The part numbers are different, but no markings.
One fits better, or goes into the housings easier than the other, but they both "fit."
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175372
12/29/08 07:54 PM
12/29/08 07:54 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
If the part number is an even number, the part is for the right side of the car. If the part number is an odd number, it's for the left.
Re: coronet 440 tail lights. Is there a right and left? [Re: rick@laysons] #175373
12/29/08 09:51 PM
12/29/08 09:51 PM
Andrewh Offline OP
Andrewh  Offline OP
Then both the tail light lenses are left.?
Because both end in an odd number.
Both backup lights end in an even number, but are the same part number.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175374
12/30/08 11:32 AM
12/30/08 11:32 AM
Andrewh Offline OP
Andrewh  Offline OP
Could someone with a 65 that they know the lights are correct on, check please. Since I know mine have been replaced at some point, I can't say for sure the guy just didn't put two lefts in, but other than the part numbers they aren't marked differently.
All the other parts that cared had a L or R on it.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175375
12/30/08 11:43 AM
12/30/08 11:43 AM
Western Oregon
bull Offline
bull  Offline
Western Oregon
What I have found is that all Chrysler parts that come in pairs for two different sides of whatever are labeled left and right, but often it doesn't matter which side you put them on.
1968 Charger 383/2bbl/4spd (1 of 74) 1994 Dakota Sport 3.9L/AT/2WD 2003 Durango SLT 4.7L/AT/4X4 Yes, all Dodges and nothing else
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175376
12/30/08 10:12 PM
12/30/08 10:12 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I can check for you, but its going to be a few days, I am out of town and away from my car.
Re: coronet 440 tail lights. Is there a right and left? [Re: NTOLERANCE] #175377
12/30/08 11:11 PM
12/30/08 11:11 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks. Got the answer from another forum. Would be nice as a double check though. He said his part numbers were the same on both his lenses.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175378
01/03/09 11:17 PM
01/03/09 11:17 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I have the same part number for the lenses:
22606016 65000-911
I looked at 5 lenses.
2449801 and 2449800 on the housings, each stamped L&R
B/U delete plates dont have any numbers...
Re: coronet 440 tail lights. Is there a right and left? [Re: NTOLERANCE] #175379
01/03/09 11:52 PM
01/03/09 11:52 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks. That is the same number on one of my lenses. the other is completly different. But that confirms what the other guy said.
Thanks again for the help.
Re: coronet 440 tail lights. Is there a right and left? [Re: Andrewh] #175380
01/04/09 01:31 AM
01/04/09 01:31 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I think wagons are different left to right on the lenses..... something about the curve.
