Main/Rod Bearing Inspection-Virgin 71 383 HP #175360
12/26/08 01:54 PM
12/26/08 01:54 PM
NE Ohio
71 FJ6 Charger Offline OP
NE Ohio
Motor has never been apart,cylinders look good. Anything to look for bearing wise that would make me want to replace them? Thanks all.
'71 383HP FJ6 Charger SE
Re: Main/Rod Bearing Inspection-Virgin 71 383 HP [Re: 71 FJ6 Charger] #175361
12/26/08 02:16 PM
12/26/08 02:16 PM
God's Country Maryland
GODSCOUNTRY340 Offline
If there are any scratches, flaking, uneven wear patterns (could indicate bent connecting rod), dirt imbedded in them or a lot of copper showing replace them. If they look good after the visual inspection check the clearance with plasti-gauge, anything over .0025 I'd replace them.
Re: Main/Rod Bearing Inspection-Virgin 71 383 HP [Re: 71 FJ6 Charger] #175362
12/26/08 03:03 PM
12/26/08 03:03 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
There will be date codes on the backs of them, should assure you of virgin status too.
