Re: Updates on the Edelbrock Victor Installed Height Saga
[Re: Jeremiah]
#1753554
02/13/15 05:16 AM
02/13/15 05:16 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I emailed Hughes (they CNC's my MW Victors to an advertised 370@.700) and Dave told me to pick out a smaller cam. Unfortunately it is a little late for that. Stupid me to consider that a head advertised to flow well at .700-.750 lift would be able to utilize a compatible valve spring without retainer clearance issues and a scrub pattern wider than a '70 New Yorker. Anyway, more contestants:
[Re: rebel]
#1753557
02/13/15 05:47 AM
02/13/15 05:47 AM
Jeremiah
Rogue River, OR
those Tool Steel retainers really help gain clearence. swapped out my titiainium for them. so far i'm impressed.
Are those Manley titanium 10 degree locks as well? How much spring pressure are you running? Thank you for the feedback!
[Re: Jeremiah]
#1753563
02/13/15 10:07 AM
02/13/15 10:07 AM
BradH
Now to my question...why?
Uhhhh... 'cuz somebody effed up?
I'll check my Hughes offset intakes & standard exhausts and see if there is a similar issue, but I don't recall noticing anything wrong when they've been mocked up on a head before.
[Re: Jeremiah]
#1753565
02/13/15 12:53 PM
02/13/15 12:53 PM
Posts: 485 Central California
MoParFish
Central California
Sorry you are having problems. That's odd that the rollers are different height. Like many Victor guys it seems, I have a love/hate relationship with mine. You may have read my combo before and I run a smaller cam but, if helps at all, here's my valvetrain combo: solid roller .421 lobe lift w/1.6 HS rockers = .674 lift. Trick Flow springs TFS-16943-16(which are actually PAC-1243)installed at 1.900, Comp tool steel retainers 1732-16 Comp 4785-16 locators 611-16 locks 621-16 lash caps, Smith Bros .375x.083 pushrods Harland Sharp S70016EVK rockers. No spring/retainer clearance issues even without lash caps. I decided to run the caps only because the sharp rockers sweep the roller from the center toward the outer tips of the valves at full lift and wanted more contact. I'm sure it's not the ideal setup but seems to be working OK. Has been to 7400 RPM a couple times but keep it below 7k now.
[Re: gregsdart]
#1753566
02/13/15 01:16 PM
02/13/15 01:16 PM
Jeremiah
Rogue River, OR
Have you checked out spring cups for thinner ones? Sounds like you are close to having plenty of clearance. How much lift is on your cam?
I am using .045 spring seats and those are the thinnest I could find. The cam is only .741/.718 net lift accounting for lash. I'm there, just need to get the pattern sorted out.
[Re: MoParFish]
#1753569
02/13/15 03:16 PM
02/13/15 03:16 PM
BradH
... I decided to run the caps only because the sharp rockers sweep the roller from the center toward the outer tips of the valves at full lift and wanted more contact.
That's an example of the HS rockers being too long between the shaft pivot C/L and the roller tip pivot C/L, unfortunately.
[Re: 451Mopar]
#1753571
02/13/15 03:25 PM
02/13/15 03:25 PM
Posts: 5,163 CT
GTX MATT
CT
Not trying to troll you here but I don't think you would have had the clearance issue if you were running Harland Sharp rockers. They don't have a gentle radius like the Hughes pieces. They cost literally 2X + as much though
