Torque spec for ARP head studs on a 340 #175354
12/26/08 01:25 PM
12/26/08 01:25 PM
Anonymous OP
Anonymous OP
We are assembling a 340 stroker using an APR head stud set for cast iron heads. We need the torque spec for this application. The ARP site gives a generic number but nothing specific and ARP is closed for the holiday weekend. Can anyone help?
Thanks in advance. P/n for the kit is 144-4001.
cuda273
Re: Torque spec for ARP head studs on a 340 [Re: ] #175355
12/26/08 06:46 PM
12/26/08 06:46 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the sheet that came with mine says 90 ft lbs with ARP moly lube or 130 ft lbs with 30 wt motor oil.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Torque spec for ARP head studs on a 340 [Re: dusturbd340W5] #175356
12/26/08 06:53 PM
12/26/08 06:53 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I did mine to 122 ft/lbs with Eddy heads and 30wt oil
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Torque spec for ARP head studs on a 340 [Re: 69L78Nova] #175357
12/26/08 11:17 PM
12/26/08 11:17 PM
calif
cupcake Offline
cupcake  Offline
calif
122 lbs ??? do,nt they call for 70-75 for alum heads
Re: Torque spec for ARP head studs on a 340 [Re: cupcake] #175358
12/26/08 11:50 PM
12/26/08 11:50 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Maybe with ARP lube. I even contacted Edelbrock after hearing of the high torque value...they suggested the same.
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Torque spec for ARP head studs on a 340 [Re: 69L78Nova] #175359
12/27/08 12:23 AM
12/27/08 12:23 AM
calif
cupcake Offline
cupcake  Offline
calif
are studs more then bolts
