swapping out an 8 3/4 rear #175329
12/26/08 12:49 PM
12/26/08 12:49 PM
Ashburn, Virginia
ashburnmike Offline OP
Ashburn, Virginia
Hello all,
I'd like to try and swap out the 3.91 chunk and replace them w/3.23 in my Dart. What does it take to do this. Do I need special tools? Is there anything I should be aware of before attemping this?
thanks
Mike
Re: swapping out an 8 3/4 rear [Re: ashburnmike] #175330
12/26/08 01:00 PM
12/26/08 01:00 PM
swapping one chunk for another? You only need a gasket w cement(my preference), several qts of the appropriate gear oil, a small bottle of the sure grip additive, Check & see if the flanges take the same size u joint, get the pumpkin seated all the way into the housing,only pull the axles out far enough for the pumpkin to come forward, adj end play when you're done. & last but not least give me 1st dibs on the 3.91
Re: swapping out an 8 3/4 rear [Re: RapidRobert] #175331
12/26/08 01:10 PM
12/26/08 01:10 PM
Ashburn, Virginia
Ashburn, Virginia
sure thing..you have first dibs. If that's all there is to it,great. it seems too easy. I didn't realize how that low a gear really runs up the rpms @ 55 mph.
Re: swapping out an 8 3/4 rear [Re: ashburnmike] #175332
12/26/08 01:15 PM
12/26/08 01:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Here's a little toy for seeing what gear and tire changes do to RPMs. http://vexer.com/68rt/speed.html
Re: swapping out an 8 3/4 rear [Re: ashburnmike] #175333
12/26/08 01:19 PM
12/26/08 01:19 PM
sure thing..you have first dibs. I didn't realize how that low a gear really runs up the rpms @ 55 mph.
yes that will be difficult to deal with but I feel up to it . The only other thing I can think if is if both of the chunks have the thrust buttons on there where the axles but together you wont have any problem with resetting your end play & you want it on the low side ~ .010" or so.
Re: swapping out an 8 3/4 rear [Re: RapidRobert] #175334
12/26/08 01:21 PM
12/26/08 01:21 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Regarding the thrust buttons, they have a tendency to fall out, so keep an eye out for them.
Youll need them for reassembly, assuming you have all oem bearings and components.
Re: swapping out an 8 3/4 rear [Re: RapidRobert] #175335
12/26/08 01:22 PM
12/26/08 01:22 PM
Ashburn, Virginia
Ashburn, Virginia
how do you adjust the end play?
Re: swapping out an 8 3/4 rear [Re: ashburnmike] #175336
12/26/08 01:28 PM
12/26/08 01:28 PM
there is a threaded adjuster on the passenger side located on the axle flange in between the brake shoes. just have the axle up on 2 jack stands during all of this(the R&R & the adjusting)
Re: swapping out an 8 3/4 rear [Re: stumpy] #175337
12/26/08 01:43 PM
12/26/08 01:43 PM
Ashburn, Virginia
Ashburn, Virginia
thanks. I wish I had that when the 3.91's went in...it's right on the money w/ the current rpms.
Re: swapping out an 8 3/4 rear [Re: RapidRobert] #175338
12/26/08 01:45 PM
12/26/08 01:45 PM
Ashburn, Virginia
Ashburn, Virginia
How will I know when it's adjusted correctly?
Re: swapping out an 8 3/4 rear [Re: ashburnmike] #175339
12/26/08 01:54 PM
12/26/08 01:54 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
you want no more then ten thousandths of an inch,you may want to borrow or buy a dial indicator,fairly cheep and handy to have. good luck
Re: swapping out an 8 3/4 rear [Re: meepmeep70] #175340
12/26/08 01:55 PM
12/26/08 01:55 PM
Ashburn, Virginia
Ashburn, Virginia
Thanks for the help everyone...off to the garage
Re: swapping out an 8 3/4 rear [Re: ashburnmike] #175341
12/26/08 03:52 PM
12/26/08 03:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
