Re: Carb spacer
[Re: joedee]
#1753343
02/12/15 08:08 PM
02/12/15 08:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hi, What is the reason for a cab spacer? Does it improve performance or is it just to lift the cab higher?
Thank you, Joe
Both... a 1/2" is basically to just lift the carb.. the 1" and 2" open add to the plenum volume... the 4 hole adds both some volume and carb signal velocity
Re: Carb spacer
[Re: AndyF]
#1753346
02/12/15 09:06 PM
02/12/15 09:06 PM
MR_P_BODY
A carb spacer almost always adds horsepower. Moving the carb away from the bottom of the intake manifold makes it easier for the air to make the turn.
I've used up to a 4 inch carb spacer when dyno testing.
A low down of your engine will help determinate if a spacer would help... on most stock engines it most likely wont do anything... but once you stroke a engine the intake tends to be to small except for some of the tall ones... even then a spacer might help
Re: Carb spacer
[Re: MR_P_BODY]
#1753347
02/12/15 11:25 PM
02/12/15 11:25 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
Myself I took two 1/2 inch spacers and drilled two holes in the sides for a pressure relief valve in each because of the intake im running...Stories of fuel puddling inside crossrams then grenading the tops had me looking for a way to save a rare old intake..I hope it works..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
