A833 trans problem #175287
12/26/08 10:35 AM
12/26/08 10:35 AM
norton mass
scotman1955 Offline OP
norton mass
SLIPS OUT OF GEAR EVERY TIME I LET UP ON CLUTCH IN REVERSE ONLY.IS IT TRANS OR LINKAGE WHAT DO YOU THINK
Re: A833 trans problem [Re: scotman1955] #175288
12/26/08 10:54 AM
12/26/08 10:54 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
check you linkage adjustment it may not be fully engaging the gears.
Re: A833 trans problem [Re: scotman1955] #175289
12/26/08 10:55 AM
12/26/08 10:55 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I would put it in gear without engine running, then get under the car and check the reverse lever, and make sure it is moving all the way into reverse. You may have to disconnect the lever from the shift rod to see if it will move farther.You could have a shifter problem also. It would be nice if you had a helper operate the shifter while you check the movement. If you see it's an adjustment problem, it will be obvious what to do.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: A833 trans problem [Re: doctor_mopar] #175290
12/26/08 10:58 AM
12/26/08 10:58 AM
norton mass
norton mass
THANKS
