Re: Street/strip diff upgrade: D60 vs 9" pros & cons
[Re: maximum entropy]
#1752507
02/20/15 08:57 PM
02/20/15 08:57 PM
Posts: 1,211 Minn
SportF
Minn
i run a dana for a number of reasons. the dana may weigh slightly more, but has less rotating drag due to the fact that the pinion centerline is closer to the ring gear centerline (vertically). granted there is tons of aftermarket support for the 9", but i just didn't want a ford based rear in my car. that and i've broken a 9". and an 8 3/4. and an 8 1/4. i also agonized over which posi to use. i have a full spool. it was the right decision for me.
This rotating effort/efficiency of rear ends I find exceptionally interesting. I have NEVER seen an actual test, figures, or calculations. As such, I believe that it really doesn't make a difference, a measurable difference. NASCAR guys do everything to extract every bit of power, yet they run a 9". Show me facts, otherwise, I say this is 50 years of bull.....
[Re: fourgearsavoy]
#1752508
02/20/15 09:30 PM
02/20/15 09:30 PM
KOS
[Re: pittsburghracer]
#1752511
02/20/15 09:54 PM
02/20/15 09:54 PM
Posts: 6,295 U.S.
moparniac
U.S.
Works for me... 550" HEMI with f2 procharger
Mopar Performance
[Re: KOS]
#1752513
02/20/15 10:12 PM
02/20/15 10:12 PM
Posts: 1,211 Minn
SportF
Minn
Interesting read here Brad http://www.hotrod.com/how-to/transmission-drivetrain/ccrp-0806-chevy-chevelle-rear-axle-swap/
Gus
read this heres your proof
Well, I stand corrected. What a great test! Man, that took some time and effort.
It stated at the end that the ET would be measured in hundred's of a second. Um, the Ford was 17 pounds lighter (balancing the brake weights). With an aluminum center you could drop enough weight to make the ET's the same????
This thread really hashed out some opinions and ideas here, so I will put mine here as well. I think the ford rear (with aluminum center) looks better than the Dana. Thanks to all for the inputs!
[Re: SportF]
#1752514
02/21/15 12:03 AM
02/21/15 12:03 AM
Posts: 345 Nebraska
451Cuda
Nebraska
Gus
And get the aluminum 9 inch center that runs 12 bolt gears, there's the winner
[Re: WO23Coronet]
#1752521
02/23/15 06:48 PM
02/23/15 06:48 PM
Posts: 1,211 Minn
SportF
Minn
Well, they are saying 12 bolt gears, and with the pinion higher, I doubt the support bearing is possible.
I don't exactly agree with someone calling the 9" a power robber, there was a 1.5% difference in power output, which could be caused by a simple temperature or barometric change. Maybe they accounted for that, don't remember reading that though. Did anybody see if they accounted for "weather/altitude" change?
Overall it was a really interesting test of rears, but what if bearing pre-load is on the high side of one rear, and low on the other.
I no doubt learned something there, but it wouldn't change my mind as to which rear I would choose.
[Re: SportF]
#1752524
02/23/15 07:40 PM
02/23/15 07:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The heavy brakes would account for most of the difference they showed.. and they made note of the brakes being heavy
[Re: Monte_Smith]
#1752525
02/23/15 08:04 PM
02/23/15 08:04 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
As somebody already stated, if there was shred of evidence that a Ford COST you ANY power or performance over the entire range, they would NOT be under CUP cars.....period. Instead of center sections for every track, they would just have complete assys. Could change them just as fast, probably faster.
I'd be curious to see if the rear end was like everything else in nascar. It's probably the only one approved to run in their major series.
