Torque converter questions #1751381
02/10/15 11:57 PM
02/10/15 11:57 PM
Jacksonville, AR
dmckeehan Offline OP
Jacksonville, AR
Couple of questions on 360 torque converters....
are there any visual differences between a lockup and non-lockup converter?
can you use a lockup converter out of a 518 in a 727?
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205
2002 3500 extended cab, 4x4, Cummins and 6 speed
1997 Ram 2500 5.9 with 35 Boggers - Mud Racer
1993 Dakota 4x4, Dana 60's front and rear - work in progress
1992 Dakota 2wd short bed, awaiting 440 swap
Re: Torque converter questions [Re: dmckeehan] #1751382
02/11/15 12:05 AM
02/11/15 12:05 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Different number of splines on them...
plus the lock up transmission has a different input shaft..
Tony
70 AARCuda Vitamin C
Re: Torque converter questions [Re: 70AARcuda] #1751383
02/11/15 09:35 AM
02/11/15 09:35 AM
Jacksonville, AR
Jacksonville, AR
thanks!
Re: Torque converter questions [Re: dmckeehan] #1751384
02/11/15 05:59 PM
02/11/15 05:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the converter has a drain plug it's definitely not a lockup.
Re: Torque converter questions [Re: John_Kunkel] #1751385
02/12/15 11:52 AM
02/12/15 11:52 AM
Jacksonville, AR
Jacksonville, AR
Thanks John!
