Cam Help RB 496 #1751180
02/10/15 07:54 PM
02/10/15 07:54 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
Looking to change the camshaft in my engine. The engine is a 496" RB with approx. 12.5-1 comp. Indy 440-1 heads (mild porting and bowl blend) 1050 dominator running E-85. the current camshaft is an older Hughes grind:HEV5663BS with 1.6 rockers INT .626" EXH .642" duration @.050 int: 256 exh: 265 lobe sep: 108 The car is 3020lbs with me in it, 4500 dynamic converter, 727 trans, 471 gears, 33" tire. Foot brake the car. It currently runs 6.20s in the 1/8th has been 9.70s in the 1/4. I had been told by Hughes I could use a little more camshaft and was hoping to get some opinions of what I should be looking for from some of you who know more than me. Thanks
Re: Cam Help RB 496 [Re: 47hudson] #1751181
02/10/15 08:48 PM
02/10/15 08:48 PM
gregsdart Offline
gregsdart  Offline
Check out the mm305 grind in the comp cams catolog. You have the cubes to use that cam, and it has great .200 duration numbers. You will need 5500 to 6000 stall to make good use of it though.
Re: Cam Help RB 496 [Re: 47hudson] #1751182
02/10/15 10:49 PM
02/10/15 10:49 PM
Dude, that is impressive, especially in that car I wonder how many racers that didn't know your car where wondering what is that car doing in this staging line the first time they saw it
Re: Cam Help RB 496 [Re: Cab_Burge] #1751183
02/11/15 12:39 PM
02/11/15 12:39 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
Thanks, the car is a lot of fun. It does catch some people off guard, But Dad's car was Much more shocking to people because its more subtle than my car. When his car had the big engine in it and was running high 9's people would really do a double take.
Re: Cam Help RB 496 [Re: 47hudson] #1751184
02/11/15 01:44 PM
02/11/15 01:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... a 496" RB with approx. 12.5-1 comp. Indy 440-1 heads (mild porting and bowl blend) 1050 dominator running E-85. the current camshaft is an older Hughes grind:HEV5663BS with 1.6 rockers INT .626" EXH .642" duration @.050 int: 256 exh: 265 lobe sep: 108... I had been told by Hughes I could use a little more camshaft...
A little more cam? I'd say you're 15-20 degrees short of what that engine wants, depending upon the converter you mentioned.
The "If it was mine..." answer is, I'd try something around 272 at .050" intake, 276 exhaust & 110 LSA installed on 106 ICL. If you had a 5K+ converter, I'd go up around 4 degrees more on both lobes.
But since all my junk are stock-stroke 440s, it's just a s.w.a.g on my part.
Re: Cam Help RB 496 [Re: BradH] #1751185
02/11/15 02:50 PM
02/11/15 02:50 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The engine combo would love a 650/650 lift-290/290-108 cl.solid flat tappet cam or 680/683-284/288-108cl roller cam.these are with 1.5 rockers,1.6 is even better.We used these cams in many builds.
Re: Cam Help RB 496 [Re: B G Racing] #1751186
02/11/15 05:32 PM
02/11/15 05:32 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
I have been looking at another Hughes cam or maybe Howards. Not really tied to any brand just want to get the most bang for the buck so to speak. What do you guys think about: Hughes: HUG STL6872BS3-8 3 BOLT .421"/.426" LOBE LIFT and 268/272 -108šLSA or Maybe a Howards:HRS-722412-08 Lift .639/.639 with 1.5 rockers 272 int./272 exh. I am running 1.6 rockers and don't want to go so big it ruins the combination.
Re: Cam Help RB 496 [Re: 47hudson] #1751187
02/11/15 05:47 PM
02/11/15 05:47 PM
BradH Offline
BradH  Offline
If you're looking for an off-the-shelf grind, the Hughes cam HERE is what I'd think is a reasonably good match.
Re: Cam Help RB 496 [Re: B G Racing] #1751188
02/11/15 10:41 PM
02/11/15 10:41 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
If you want it right, listen to this man.
Re: Cam Help RB 496 [Re: B G Racing] #1751189
02/11/15 10:46 PM
02/11/15 10:46 PM
This man has built more than anyone else you can name--Believe Him!
That 650 solid dialed in right--I like advanced to around 102 in a 440 and 105 in a 500 ( we usually race 1/8th) is one of the best cams in that combo on earth! Fiddle around with numbers until you go blind--it will still beat 90 % of the choices you will make--You were talking to another cam guru at Hughes--and ??
That 650 solid will shock you at how well it works--Period! It really needs stout springs and titanium retainers are a 100% MUST with it as well but when degreed correctly it is unbeatable with your combo-which is a classic BTW I have used dozens of them over the years and have never been unhappy. Depend on folks that have built Hundreds of big blocks not a few
Re: Cam Help RB 496 [Re: 47hudson] #1751190
02/11/15 11:21 PM
02/11/15 11:21 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
3020#... That is light,,,the car doesn't look 'light'.
If you like drag racing, support your local track.
Re: Cam Help RB 496 [Re: CHAPPER] #1751191
02/12/15 12:42 AM
02/12/15 12:42 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
cool car....
sorry i didn't catch if you had a solid roller in there now,
Re: Cam Help RB 496 [Re: 47hudson] #1751192
02/12/15 10:54 AM
02/12/15 10:54 AM
gregsdart Offline
gregsdart  Offline
These cams leave hp on the table. As long as you match the converter to the cam, you can run a LOT more duration than you now have. Look at BGs recommendation, and mine with .200 duration numbers of 200 on the 290 cam and 197 on the mm305. Those cams come close to roller cam specs.
Of the roller cams I have used in motors like this, non were less than 280 @ .050 on the intake, and non were less than 197 duration at .200. This combo of 440-1 heads and 500 cubes work well with that much duration. High lift won't hurt you provided you have clearance and good springs. The extra lift is also what puts you where the heads flow well also. Mildly ported 440-1s don't reach full flow till .700+ lift. A common rule of thumb for best performance is to open the valve .35 times the intake valve diameter which is more than .700 with your heads.
I haven't run them, but the word is the newer Beehive springs are the hot deal, and worth looking into.
Re: Cam Help RB 496 [Re: gregsdart] #1751193
02/12/15 12:35 PM
02/12/15 12:35 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
Thanks for all the info, that's a lot bigger bump stick than what I was looking at. I will be changing the springs to match the cam but I am still running the original Indy rockers, retainers etc. that came on my heads, am I going to go beyond what these parts will regularly handle? I don't have much of a budget so I need to make sure my parts will last a few seasons. Other than the Hughes cam mentioned does anyone have a shelf part # for a good cam I need to purchase the cam lifters and springs soon.
Re: Cam Help RB 496 [Re: B G Racing] #1751194
02/12/15 01:01 PM
02/12/15 01:01 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Thats the stick "the Man" put in my ride (.650) works very well and I run it pretty detuned.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Cam Help RB 496 [Re: 47hudson] #1751195
02/12/15 01:11 PM
02/12/15 01:11 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use these cams with the Indy rockers and retainers with good results.Choose a good spring with aprox.225 to 250 lbs on the seat and 500 to 600 lbs. open.For best upgrades use 10 degree titanium retainers and 10 degree locks then you can use a little more spring pressure if you want.With the setup we have mentioned you can get a lot of service and life.The cams can be purchased through Comp Cams and Indy.
Re: Cam Help RB 496 [Re: Eric] #1751196
02/12/15 01:12 PM
02/12/15 01:12 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i would change the converter to a 53-5500 before I change the cam. Even if you change the cam you will still need to change to converter
Re: Cam Help RB 496 [Re: B G Racing] #1751197
02/12/15 04:24 PM
02/12/15 04:24 PM
Northeast Georgia
47hudson Offline OP
47hudson  Offline OP
Northeast Georgia
Ok what I am coming up with is a Comp 23-650-5 cam, Comp 821-16 lifter, and Comp recommends a 925-16 spring? Sorry for asking so many questions but I would like to get all this nailed down so I can order some parts. Then I just need a summit discount code!
Re: Cam Help RB 496 [Re: 47hudson] #1751198
02/12/15 04:32 PM
02/12/15 04:32 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Cant help on the info but please post your results when you take it out because i'm thinking of giving this cam a try in my 440.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Cam Help RB 496 [Re: B G Racing] #1751199
02/12/15 04:49 PM
02/12/15 04:49 PM
NC
440Jim Offline
440Jim  Offline
NC
Those pressures are a lot higher than the Comp 925-16 springs.
