2008 Ram 1500 Hemi 4x4 T-case problem. #1751126
02/10/15 04:58 PM
02/10/15 04:58 PM
Tulsa OK
Bad340fish Online content OP
Bad340fish  Online Content OP
Tulsa OK
I have posted about the auto 4wd not working properly in my 08 Hemi Ram before, I can't find much information on that but the four wheel drive problem got worse this weekend.
I put the truck in 4-low to back it up my steep yard because I didn't want it to spin the tires on the grass. When I tried to put it back in 2wd the volt meter pegged to the high side and my blower motor cut out and back on several times. It did not complete the shift back to 2wd. I set the e-brake and continued my work. I came back out to the truck and when I started it the transfer case was in Neutral, it was indicated by the N light on the 4wd switch and the truck would roll while in park.
I read the manual on how to remove it from neutral and that procedure didn't work. It would try and then revert back to N on the indicator. I also unhooked the battery for awhile, checked all the fuses, etc. No luck.
Next I pulled the shift motor off of the t-case and moved the control manually. First I found low range again, next I found 2wd and I moved it out of the yard. I messed with it some more and somehow ended up with 2wd lo range(front shaft spins freely) not sure how that happens. I moved the lever some more and got it back to 2wd.
Now I have a service 4wd light which makes total sense since the shift motor is off of the case and unplugged. However, on the first start in the morning the 4wd light is on and the front axle is connected(driveshaft locked in via CAD) but the t-case is not in 4wd. After I stop at the store for my morning drink it goes back to the service 4wd light beieng on like I would expect.
Sorry for the long post but does anyone have any idea what I am up against? I talked to the dealer and they will look at it for free or an hours labor if they gotta dig in. If its not module or computer related I will do all the work. I can dig into the t-case that doesn't scare me, but I don't want to dig in and find the problem is electronic.
And Lastly, what scanners will let me see 4wd operation? Does it take the chrysler scan tool to do so? Thanks for any help.
Its Frusterating that I abuse my jeep like none other, put it in 4wd while sideways with the rear tires spinning, broken axles, broken drive shaft joints, all this and the t-case is fine. I have this creampuff ram that never goes offroad and the 4wd is acting up LOL.
68 Barracuda Formula S 340
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751127
02/10/15 07:43 PM
02/10/15 07:43 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Not sure of the problem but I've heard the TIPM causes various electronic issues on the 06 and later Ram.
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751128
02/10/15 08:23 PM
02/10/15 08:23 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
After you backed up the hill, was the truck on level ground and in neutral when you tried shifting it from 4lo into 2hi?
Mo' Farts
Moderated by "tbagger".
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Grizzly] #1751129
02/11/15 12:28 AM
02/11/15 12:28 AM
Tulsa OK
Tulsa OK
Not on level ground but in neutral with e brake on.
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751130
02/11/15 01:38 AM
02/11/15 01:38 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Well not sure what your problem is ....but if you need parts I have them! I have a T case out of a 2008 Ram 1500 that only had 42k miles and the electric shift motor. So if you need to replace one of those give me a PM.
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751131
02/11/15 02:37 AM
02/11/15 02:37 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
If it was still pointed downhill with all that weight and torque on those gears/collars in 4lo and then switched the electronic shifter to 2hi, that shift motor is trying to pull against all that pressure. By the lights on your dashboard and heater motor cutting out it would sound like an electrical overload and you burnt out the shifter motor.
But if you say it was in neutral when you shifted it, then I got nothin'.
Mo' Farts
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: hemi70se] #1751132
02/11/15 11:13 AM
02/11/15 11:13 AM
Tulsa OK
Tulsa OK
Is it the NV246 t-case with the auto four wheel drive?
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751133
02/11/15 12:28 PM
02/11/15 12:28 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
as for your light indicating 4wd, the light is actuated off the front axle CAD (atleast is was in early 2000s) so if the cad is locked in, the sensor thinks its in 4wd
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: ViperDave] #1751134
02/11/15 01:52 PM
02/11/15 01:52 PM
Tulsa OK
Tulsa OK
Thank you, its looking like replacing the CAD is going to be a good route to go. It will lock in on its own. There seems to be lots of issues with them having shorts.
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751135
02/20/15 03:13 PM
02/20/15 03:13 PM
Tulsa OK
Tulsa OK
I would never have guessed this but the transfer case shift motor was bad. They replaced that, cleared codes, and its all good.
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751136
02/21/15 01:33 PM
02/21/15 01:33 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Ha, I nailed it. What's my prize?
Thanks for updating, I have that set-up in my '07 too (without the AWD though) so this is good info. How much to fix it?
Mo' Farts
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Grizzly] #1751137
03/16/15 10:19 AM
03/16/15 10:19 AM
Tulsa OK
Tulsa OK
Update
First bill was $600 it seems the NV246 motor is much more expensive than the regular one.
The second was free under warranty after one week, the third one was also replaced under warranty after another week. THEN the TIPM was replaced for another $760 and all seems well now. It shifts in and out much faster than it ever has. It seems the TIPM has been killing the t-case motors, didn't make sense to me at first but it has obvious different behavior when shifting in and out now.
This threw the dealer for a pretty good loop. They opened a star-case with chrysler and worked on it for days and had me in a loaner for 11 days between the two warranty failures most of which was waiting for parts while this area got hit with some winter weather.
It was expensive but the dealer was honest and straight forward with everything.
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: Bad340fish] #1751138
03/17/15 10:09 PM
03/17/15 10:09 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Seen this problem while working at the local dodge dealer on 3 trucks. All 3 were 08 1/2 tons. Don't really know why it was just this particular year and model having problems. I'm thinking a programming issue with the TIPM. The actuator is the same part used for several years prior without issue. One of the trucks shifted the transfer into neutral and rolled down the owners driveway on its own. Shift actuators were first installed on 2 of the trucks but both came back shortly there after to have the TIPM and shift actuator replaced again. The 3rd truck got both a TIPM and
actuator first visit. STAR said one was causing the other to fail so they must be replaced at the same time.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2008 Ram 1500 Hemi 4x4 T-case problem. [Re: 71yelladustr] #1751139
03/18/15 11:20 AM
03/18/15 11:20 AM
Tulsa OK
Tulsa OK
When mine first messed up it went into N, luckily I had my e-brake on because my driveway is steep!
