518 swap, anyone got the diagrams? #175077
12/25/08 11:00 PM
12/25/08 11:00 PM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
Going to be getting a 518 non-lockup ready to go into my '81 D-250. The trans is out of a '90 1/2 ton Club Cab longbox so I've got all the crossmembers and driveshafts, and I know it will fit.
What I need is the basics for running pressure switches and vacuum switches for the OD on/off. I dont really feel like toggling a switch at every single stoplight to kick the OD in and out. I will have one however that will kick it out when I'm towing loads.
Anyway I need specifics on what to wire to where, part numbers for the vacuum switches, and I think I read somewhere on here about an A/C cutoff switch for kicking the OD in and out at a specific speed. something like a 44 PSI switch works out at 44 mph if my speedo is right (its only off a small amount, fast by about a mile or two).
I'd like to get this info now, because I'm looking at doing it in the spring and I want to have it and everything I need on hand so I can go to work on it when the time comes. Maybe we should stick this thread in the tech archives for others to see when its done.
If anyone wants a how-to I'll use my truck as a guinea pig.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: 518 swap, anyone got the diagrams? [Re: MoPar Jamie] #175078
12/25/08 11:02 PM
12/25/08 11:02 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Re: 518 swap, anyone got the diagrams? [Re: NITROUSN] #175079
12/26/08 12:35 PM
12/26/08 12:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'm doing it now with a lockup trans in my 74 D100 and it's been done a number of times before by guys here. Nothing new. PATC transmissions has the instructions. The pressure switch comes from chevy 250 & 350 transmissions and cost about $5 at the trans supply. It's the thrid gear clutch switch. I think the part # is A44416AA. The letters at the end are the code for the pressure. That # comes in everything from 55 to 40psi depending on the last letter or letters.Drive shaft will need to be 3.5" shorter also. If you aren't using a lock up then you just need a toggle switch for on and off and a pressure switch for in and out of OD.
