Re: B-body disc brake swap
[Re: elmor353]
#1750272
02/09/15 09:12 PM
02/09/15 09:12 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You're positive that the master cylinder is bottoming out?
What is the distance from the brake pedal pivot to the master cylinder push rod?
[Re: elmor353]
#1750273
02/10/15 05:09 PM
02/10/15 05:09 PM
Posts: 25,951 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Was the '65 Coronet originally manual brake or power brake? (thinking incorrect pedal ratio)
[Re: elmor353]
#1750276
02/10/15 08:01 PM
02/10/15 08:01 PM
feets
Senior Management
Senior Management
Irving, TX
Do you have any free movement in the pedal or is it always putting pressure on the master cylinder?
[Re: elmor353]
#1750278
02/10/15 09:40 PM
02/10/15 09:40 PM
feets
Senior Management
Senior Management
Irving, TX
Then you are likely bottoming the MC. You should have an inch or so of free pedal movement.
Your choices are to either space the MC away from the firewall or get a shorter/adjustable push rod.
